Technical 1937 LaSalle Transmission - Clutch Disk Info Needed
Discussion in 'The Hokey Ass Message Board' started by Ebbsspeed, Jan 6, 2022.
  1. Ebbsspeed
    Ebbsspeed
    I'm in the midst of building a Model A, Flathead Cadillac powered with a '37 LaSalle trans behind it. The clutch disk I have is worn, and instead of having it rebuilt I'd like to see if there is a drop-in replacement from some other application that would be reasonably priced. Specifications:
    10 Spline Input Shaft
    1.25" Input Shaft Diameter
    10.5" or 11" Disk Diameter
    Ford had some transmissions behind their 460 that had the 10-Spline 1.25" input shaft, but they are all 12 inch disks.
    If you know of something that'll work I'd appreciate it.
    Thanks folks!
  2. Paul
    Paul
    Editor
    I'm using an '88-'94 Ford Super Duty Centerforce #381040 11"
    'may be tough find now, last time I checked they were discontinued.
    TrailerTrashToo likes this.
  3. Ebbsspeed
    Ebbsspeed
    Thanks Paul. That got me in the ballpark, and after a bit of hunting I found another for the same truck that will appear to work. It's a #CP31103A which looks like it should do the trick.
    TrailerTrashToo and Paul like this.
  4. dwollam
    dwollam
    I called a clutch place in Portland Oregon, Portland Friction maybe? Told them what I wanted and had it in a few days. 331 Hemi, LaSalle trans, Mopar 10.5 pressure plate. They did me a 10.5 disc.
    Dave
    Automotive Friction maybe? autofriction.com In Damascus Oregon. Old family business.
    Paul likes this.
