I'm in. My first car was a '37 hump, a statement that makes me sound much older than I am. I was 12, it never got finished. Another is on my someday list however.
Bolted the entire body with new pads and bolts, bolted down the floor I made, and the tool tray, and welded everything together. I also have the gas tank in to check clearance. rear seat area will eventually be redone, but its solid enough to get the worse parts done. Newsflash: coupe fenders don't fit a sedan. until you cut and weld, cut and weld, etc.....wanted to get these roughed in before I finish the rear body. right side original, left side modified. still need to sort the holes for the bumper brackets also bolted in the windshield frame, winder, dash, cowl vent, etc. to test fit. found out I have an original wiper in the box that came with the chassis, and found this badass heater to hang under the dash
Hey guys, got caught up moving to a bigger place last fall, didn't work on it much, but I have acquired an original radio and a much nicer grill. Dropping the motor in next....
