Technical 1937 ford flathead hot starting problems, help
Discussion in 'The Hokey Ass Message Board' started by hdalex, Apr 16, 2014.
  1. hdalex
    hdalex
    hi,
    i have a original 1937 ford coupe with
    flathead, 6 volt, positive ground.
    car starts right up and runs smooth, but when i turned off, it will not start again.
    changed coil, condenser and resistor...
    when its cold, starting good again!!!
    jumperwire from battery to coil starts good when warm!!!! resistor gives 3,5 volt to coil.......
    any suggestions?????????
  2. hdalex
    hdalex
  3. ROADSTER1927
    ROADSTER1927
    I do not think you need a resistor on your 6 volt system.
  4. hdalex
    hdalex
    its original, behind the dash!!!
    if you use the orig. coil, you have to use it!!!
  5. Saxon
    Saxon
    from MN
    Coil or condenser is the usual suspect. But you have changed that. New doesn't always mean good. Might want to look down the carb when it's hot and see if your getting any gas.
    Nice 37!
  6. hdalex
    hdalex
    have a electric fuel pump...gas is not the problem!!! no spark when started once!!!!
    i am thinking of another coil/condenser... got a new old stock, but will order a new setup!!!!
    i could place a switch with 6volt on the dash, to solve the problem, but this must work in a original way...;-)))
  7. Saxon
    Saxon
    from MN
    OK!!!!!! :] Ya never said when it was hot that it had no spark. Just that it wouldn't start.
    It is very possible the nos coil is dry.
    So the answer is right in front of you.
  8. Saxon
    Saxon
    from MN
    I sent you a few pms, but I'll just post it here too. As I mentioned in the pms, do a search for skip coils (here and google) and see what comes up.
    http://www.fordcollector.com/coils.htm
    Might check cracks in the dizzy cap and rotor too.
    Enjoy.
    Diode hard start solution, courtesy of www.earlyfordv8.org.
  9. hdalex
    hdalex
    ok, so you think that the new coil also fails??? have a new condenser here, will try it first, but if it doesnt help, i have to order a new coil......
    the ignition system is not very complicated, but if you get new shit parts, it wont work;-))))
  10. Saxon
    Saxon
    from MN
  11. 40LUV
    40LUV
    from Mid Jersey
    I used to have the same problem. As already recommended, send your coil to Skip. Another thing, which is pretty basic, but make sure your battery cable is the right gauge for 6 volts.
  12. hdalex
    hdalex
    all cables are new and the ground points clean!!!!
    distributor overhault (macs) with new points, adjustments done.....
    will contact skip, thanks !
  13. Topgunnz21
    Topgunnz21
    from socal
    Sounds to me that it's your distributor itself..I had the same problem with mine and someone pointed that out to me so just to humor myself I borrowed one from a friend because what are the odds that i have 2 bad distributors right..dropped it in and it fired right up..something on the inside of mine gave out and in fact it started to arc within the distributor when I would try to restart after it's warm up..good luck.
  14. ventilo
    ventilo
    I've got a NOS Bosch coil for the front mounted '37 distributor. Drop me a note if you're interested. Also got a spare dizzy.
