Technical 1937 ford coolant sender location?
Discussion in 'The Hokey Ass Message Board' started by 1LIFE2LIVE, Mar 18, 2017.
  1. 1LIFE2LIVE
    1LIFE2LIVE
    In the process of putting a 37 ford truck together I bought in pieces. It has the original gauges and the temp gauge works so I was hoping to reuse it. Problem is I can't seem to figure out where the sender goes into the engine. The only port on the head is to small and the bulb won't even fit let alone the threaded end. I feel like I'm missing something can anyone help? [​IMG][​IMG]
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    I can tell you those inlets get very corroded over the years. Odds are your hole needs a good reaming.
    Normally it's a very tight fit even without corrosion.
  3. 1LIFE2LIVE
    1LIFE2LIVE
    I was thinking the same but it doesn't look like the plug that was in the head has ever been out. I was thinking about drilling the hole out bigger and taping it to fit
    tb33anda3rd likes this.
  4. Petejoe
    Petejoe
    from Zoar, Ohio
  5. Jack E/NJ
    Jack E/NJ
    from NJ
    I think the wells might be FPT. Looks like a 3/8-24 NF bolt was used to plug this well. So it's probably a 1/8-27 FPT well. Jack E/NJ
  6. 1LIFE2LIVE
    1LIFE2LIVE
    Ok chased the threads and can now get the bulb to fit in but it sits flush on top of the head with no way to thread the nut into the head. I must be missing something. Plus the nut has a much larger hole through the center so there's no way it will seal. [​IMG][​IMG]
  7. Jack E/NJ
    Jack E/NJ
    from NJ
    Just checked my 21-studder's well. It's 3/8 FPT. The sender doesn't use a nut. It's electric. Different than your setup. Jack E/NJ
  8. AVater
    AVater
    1. Connecticut HAMB'ers
    Any chance it mounts in the water pump?
  9. Jack E/NJ
    Jack E/NJ
    from NJ
    Ask the question on the barn. Jack E/NJ
  10. junkyardjeff
    junkyardjeff
    There might have been some kind of adapter to make it work or the 37 used a different style of head.
  11. 42merc
    42merc
    Looks like you have the remnants of a plug or an adapter in the head.
    The hole should be 3/8 NPT (pipe thread).
    Originally there was a brass adapter that screwed into the head & accepted the temp gauge capillary tube & nut. A Ford item, you might need to advertise for one.
  12. 1LIFE2LIVE
    1LIFE2LIVE
    I don't think there is anything left in the head. Finding the adapter I guess is what I need to do. I'm not seeing it listed for sale on macs site. Guess I'll ask this question at the ford barn. Thanks for all the help hopefully I can find what I need to keep the factory gauge
  13. 1LIFE2LIVE
    1LIFE2LIVE
    Just to put some closer to this thread and maybe help someone in the future I found the adapter bushing needed to install the original gauge. The old steel bushing was broke in the head. I managed to drill most of it out and clean the rest out with a 3/8 npt tap. I got the bushing at Napa part number g60615-0606. It's a 3/8 npt male to 5/8 female bushing.
    Petejoe likes this.
  14. 42merc
    42merc
    A question, does the NAPA bushing have a seat for the capillary bulb so the nut will tighten against it ?
  15. 1LIFE2LIVE
    1LIFE2LIVE
    Yes it does have a seat for the capillary tube. Everything is installed and once I get coolant in it I'll know if it's sealed
