Hot Rods 1937 Dodge Ol Bessy is Coming Home....redux
Discussion in 'The Hokey Ass Message Board' started by Sharps40, Oct 5, 2018.
  1. Sharps40
    Sharps40
    Fatman responded. Finish it. Settle some. Then trim coils. Bowing is normal for now.
  2. Sharps40
    Sharps40
    As for the small cap hei's yes, they all seem to be aftermarket and mostly need a control box. I have an older Accell vacuum advance hei, small cap, in dads 47 chevy truck. Would like similar, just not an accell product, and I see summet has one like it in stand alone, but $250ish. I think if a large cap will fit behind the dual rochesters, and if so, I'll go with that. Dosn't look as nice but once the motor is set in place we'll see what we can work with. I see several of these old dodge and plymouths with small blocks in place and no firewall mods, room even for a factory fan. I have a 4" set back in the firewall, so I don't think we'll have any clearance issues front to back on any small block chevy selected for this project.
  3. Sharps40
    Sharps40
    Dad...
    Glove box latch found and installed...shop lost all the good interior handles but I had a set of spares. Not as nice but polished and installed. All door locks and risers now lubed and working.
    20190826_183845.jpg 20190826_183836.jpg 20190826_181247.jpg 20190826_190139.jpg
  4. Sharps40
    Sharps40
    I don't really like the rubber from Mopar Direct. Plenty soft and nice quality but small in all dimensions compared to original seals. I may try the front rubber components from Andy Bernbaum. I can't afford the Lynn Steele stuff, its priced so high. Must be made of Unobtainium.
  5. Sharps40
    Sharps40
    Dad,
    I'm no professional restorer/hot rodder....but I put my hands on her/your car every night for a couple hours. They wouldn't do that. She'll be a mix of new and old. Professional and amateur. But in the end, every original and new part will function properly and look at least good.
    Started cleaning up the windshield frame, inside is scuffed, primed and painted. Couple days, I'll flip it over and treat the face. Not willing to risk breaking the frame to remove the glass and the rubber is good in any event, still soft and pliable and no checking at the tight corners.
    Started cleaning up and painting the front vent wing frames. I found a complete set of hardware and trim for each. One wing primed and painted. The other wing still in the cleaning up stage. The stainless and chrome hardware polished nicely.
    69243198_2874137892656683_7225255437170376704_n.jpg 69381353_2874137715990034_5675471339436113920_n.jpg 69489788_2874137845990021_2296900453511725056_n.jpg
  6. Sharps40
    Sharps40
    Dad,
    Finished installing chrome hardware on the vent window frames for the front door. Finished the sanding and painting of the windshield frame. I removed the stainless trim for cleaning. Its looking somewhat better. Will install in 48 hours when the paint dries hard. Also located the steering column drop spacer that the shop lost. $50 for the proper tapered spacer but, where else ya gonna find a critical 83 year old part than on Ebay? We will see if we can use the oversize hole they drilled in the firewall behind the head for the column. If not......I'll figure it out. Coulda used a 1.5" hole rather than a 2 1/4" hole.....HA! Maybe i can use that hole for a wiring bulkhead if its not right for the column. Coming along. I'll call this weekend. Time to buy the last of the rubber and glass channel and get her buttoned up in the next week or two.
    69136421_2876819532388519_5487022871865720832_n.jpg 69219454_2876836432386829_4613310095885860864_n.jpg 69734726_2876819569055182_5563181240548327424_n.jpg 69868520_2876819492388523_867607699011928064_n.jpg
  7. Sharps40
    Sharps40
    Dad,
    Windshield stainless trim is pressed and crimped back on. Just got to clean the glass and rubber for the installation on the car.
  8. Sharps40
    Sharps40
    Dad,
    Worlds first Bug Induction System is back online. Brought to you by Dodge, because they care. Not even an Indian Motorcycle can so effectively channel protein supplements directly into your mouth as you motor down the road. Seal is good, window opens full and the crank mechanism works like a champ.
    69271918_2879423142128158_5490311992180736000_n.jpg 69154422_2879423208794818_8253996917420195840_n.jpg 69254002_2879423272128145_9100358409651224576_n.jpg 69318356_2879423345461471_1792823927509090304_n.jpg
  9. That’s awesome
    Sharps40 likes this.
  10. Sharps40
    Sharps40
    Dad,
    Parts are on the way to finish buttoning up Ol Bessy.
    Shipping 2 weeks out:
    2 Front Vent Glass Panels
    1 Front Drivers Roll Up Window Glass
    Shipping Today:
    2 Front Vent Wing Rubber inserts
    2 Front Roll Up Vertical Division Seals
    2 8' Sections of Window Glass Sweeper
    24 Feet of Roll Up Window Glass Channel
    1 Set Top of Door Seals
    1 Pair Headlight Rubber Inserts
    7 Feet of Hood to Cowl Lacing
    4 Rubber Hood Corners
    1 License Plate Bracket Pad
    Not much left in the way of rubber requirements after this but a handful of door, hood and glove box bumpers and bumper grommets.
  11. Sharps40
    Sharps40
    Dad,
    First time Ol Bessy had her trunk shelf in place, in my memory. So, call it 50+ years without its shelf. Originally, the shelf came all the way to the trunk lid and the spare tire under it had hold down clamps accessible at the lip of the deck. Since the floor is nicely replaced and all those clamps and fittings long gone, I put in a half shelf and we'll mount a compact spare under the shelf on the passenger side. The shorter 20" shelf will leave room to install and access a center hold down bolt for the spare, jack, etc. After thats in place, just like originally, i'll install an off center support for the shelf that runs from the shelf edge to the trunk floor. Then she'll be roomy enough to carry three dead deer or 2 big coolers full of them and our rifles......looks like room for a nice 4 gun rack right there on the back of the back seat across the big X member.
    69180634_2881924751877997_6284841810493702144_n.jpg 69278444_2881924671878005_3761672421015289856_n.jpg
  12. Sharps40
    Sharps40
    Dad,
    Having committed to Gunsmithing over nearly 40 years, I have acquired a rather eclectic mix of thread cutting taps and dies.
    On shutting the door, the sole lock on the car popped out and hit the floor. No worries, no key for that one anyhow.
    Dug through the parts inventory and found Bessy's original door lock and key. A good start. The set screw tube, like all of these old cars, had long since rusted and required the shop to drill out the set screw. Doing so destroys the 10x32 thread.
    No worries, off to the gun box where i round up those ancient taps, dies and screws used to repair rifles from the turn of the century when all the threaded fasteners were equipped with odd ball thread pitches.
    In this case, the seldom used these days size of 12 x 24 threads per inch cleaned up the set screw bore and I scrounged up a nice new stainless steel screw and lock washer for the job.
    Everything lubed up and working and with a toothpick to guide the floppy square shaft of the lock cylinder, in it went. Cinched it all down and viola!
    Bessy's Passenger Side front door locks and unlocks properly.
    As you will recall, Dodge pushed Safety in 1937. As such, all doors lock from the inside by raising the door handle. You were to enter and exit the car curbside and lock the final door using the key, thereby never standing in or opening a door into traffic. (Of course Dodge has a steel dash.....but they advertised recessed knobs and controls to prevent injury.....I suppose flattening your face was fine so long as there were no projections to cause a depressed skull fracture. :) )
    69252817_2883446121725860_3185684948338081792_n.jpg 69519946_2883446205059185_8051521206920151040_n.jpg 70250613_2883446075059198_2414345260479021056_n.jpg
  13. Sharps40
    Sharps40
    Going to have to make new chock blocks to keep Ol Bessy still in the garage. My lil helpers, Gracey and Ruger, come down each day, pull the chocks out from the wheels and proceed to gnaw them into toothpicks.
    69266784_2883446418392497_3407227942810419200_n.jpg 69574373_2883446355059170_6397149252459429888_n.jpg
  14. Sharps40
    Sharps40
    Dad,
    Getting ready for receipt of glass, rubber and window felts.
    This morning, finished setting up the front door check straps and installed 6 of 8 pins in the door and window handles. Just got to make two more pins to replace the missing ones.
    Also, preparing the front window risers for Drivers and Passenger side front doors. The best of the four vertical division bars are polished and awaiting their felts and sweepers.
    The best of the window risers were chosen, stripped and painted. I'll do final assembly of the stainless division bars to the painted risers, and in about 2 weeks it'll be glass time. Probably set the glass in urethane rather than try to beat them into place using the old school butyl rubber tape. Less chance of breaking the glass. At $50 to $70 per pane, I'm glad to tell you that you only had to buy three pieces of glass.
    69311590_2886341924769613_5995340574993940480_n.jpg 69349974_2886342254769580_6828022278559629312_n.jpg 69506893_2886342128102926_7039914928194453504_n.jpg
  15. low budget
    low budget
    from Central Ky
    Looks close enough for a real good cleaning from the dust, I couldnt resist rolling it out,washing it and letting it breathe a little, for a second wind and kind of fresh start at this point:D
    Looking good, keep up the good work:cool:
  16. Sharps40
    Sharps40
    Yeah, she's dirty....courtesy of the shop. Once its buttoned up, I'll rinse it, right now, just trying to stay off the paint with all the dirt they shipped to me with the car!
    Of course, once I wash it, I'm liable to find even more spots they damaged in the final rush to get the car out of their way. Once its all up, I'll investigate whether or not it needs to go to a new body shop to do all the myrad touch ups. I am sure the dash has to be reshot, they destroyed it tossing in all the unwrapped steel parts.
    dwollam, chryslerfan55 and low budget like this.
  17. Sharps40
    Sharps40
    Dad,
    Shop lost/did not send the chrome bumper brackets that mount the fog lamps that I converted into Run/Turn Lamps for Bessy's front end.
    Additionally, I received the crusty rusty peeling bent parts car front bumper uprights instead of the nicely straight and shiny chrome ones that were on the front bumper to begin with.
    So, I yanked the crusty bumperettes rather than spend a hundred or more to get new lamp mounts and decent bumperettes. If I ever find another pair of either part in good condition I'll grab them up and put them on.
    For now, a temporary bracket was made up and the lamps put in place to see how they ride. Pretty good I think, the bumperette holes line up better under the headlights than just about any position possible on the bumper braces. Overall, a win I think.
    Now to get some stainless steel carriage bolts to polish up and some heavier gauge steel to make a more sturdy bracket and finish the job.
    Ol Bessy will finally have run and turn lamps out front, only took 83 years to find a way to do it.
    69381740_2886979681372504_1987835173827248128_n.jpg 69508836_2886979561372516_2195828650287300608_n.jpg
  18. Sharps40
    Sharps40
    Dad,
    We had made up rear lamp brackets for inside the buckets. Fitted them to, before the buckets were painted. They provided positive ground, dual bolt mounting and wired for brake, run, turn and flasher.
    Rather than use them as intended, including all the stainless steel hardware, the shop cut them up and installed them in there loose, no grounds, lots of vibration that would have broken the filaments with each bump in the road. So......I rebuilt them again.
    Anyway, we have good grounds by wire instead of through the bucket, fender and body to frame. Only a single bolt was usable for mounting but the brackets are sturdy and shouldn't shake loose.
    Tested here with a 9v battery, both are working fine.
    Also, I found that the left over seal material for the cowl vent makes an excellent back of the lens retention gasket.
    69625264_2889450621125410_9165500208694427648_n.jpg 69771617_2889450774458728_7997342840180965376_n.jpg 69988241_2889450904458715_6087464088735055872_n.jpg
  19. Sharps40
    Sharps40
    Dad....
    Good news. Rear is 1970 to 72 Chevelle 12 bolt. Stamped E so it may be positraction. Either way...the most desirable rear for a street rod. Have to open it up but thinking positive.
    dwollam and chryslerfan55 like this.
  20. Sharps40
    Sharps40
    Dad,
    Big box of rubber and glass sweep arrived. Glass comes in 2 weeks.
    Tonights work:
    1 Front door division bar sweeps installed. Once i figured out it had a thick and thin side, both went right into place.
    2. Hood lace installed. I'll replace the screws with stainless steel later, much safer for now to self drill and tap the threads using hex head screws. Hood fits snug, very little rattle now.
    3. Four hood corners installed. These just need stainless split rivets (Brass was original) or perhaps something as simple as Chicago Screws in the holes.
    4. Headlight to body seals installed. There are none for the 37 Dodge sedans. But, 37 Plymouth sedan seals are very close, a touch of trimming inside and they mounted up just fine.
    Headlights were color and cleared. Never buffed. They don't feel smooth. But I've been making some grand progress using fff gunstock rubbing compound to buff up the many marks and flaws in the paint that were added by the shop during the move to their new workspace. The clear is buffing up fine and a test on the headlights is giving a nice smooth finish with some light hand rubbing. I figure if fff gunstock compound is good enough to bring a Browning rifle stock back to as new condition, it oughta work for clear coat. So far so great!
    69398471_2893175204086285_2773068505363251200_n.jpg 69477183_2893175067419632_1879180670266245120_n.jpg 69580802_2893175120752960_2702025936651419648_n.jpg 69762294_2893175270752945_5230480017099587584_n.jpg
  21. Sharps40
    Sharps40
    Dad,
    You've had me working on and under Ol Bessy for as long as I can remember. The earliest jobs were checking and changing the ammeter fuse before each night trip and making sure we had enough fuses in the glove box to have headlights all the way there and back. I remember when I was 8 or 9, Joppa Town Maryland, Ol Bessy failed inspection for an exhaust leak. You showed me how to fix it, hangers cut and straightened into wire, coffee cans cut into strips, wrap the pipe at the leak with coffee can smeared with muffler cement and twist the coat hanger wire tight around the coffee can patch. Go for a ride to heat it up and seal it for re inspection.
    And all those years and all those cars I put weather stripping and rubber seals on using 3M adhesive. Just like you taught me, smear a coat on the steel and the rubber, let it dry, pull off all the stringy stuff that got on everything and every place you didn't want it, smear on another light coat of 3M goo on the rubber, press and hold.
    Where the hell was 3M weather strip tape when I wore a younger mans clothing? Peel, stick to rubber, peel, stick to car. Done. No strings and no black or yellow goop on my hands for days.
    In the time it took for you and I to wrap an exhaust pipe in tin and wire, all four doors are sealed.
    Thank the Good Lord its the 21st Century.
    70003693_2895747900495682_1213030783095144448_n.jpg 70318024_2895747853829020_3382072611415523328_n.jpg
  22. Sharps40
    Sharps40
    Dad,
    Off duty for the hurricane (no worries, I'm in the mountains over 4 hours from the coast and more than 1.5 hours from the edge line, getting some rain here but not expecting more than flooding the roads and low water crossings). So, since I don't have to "work", I went to work this morning on your Ol Bessy.
    Window sweeps. I have enough to do all 4 doors, both garnish side and exterior side. For now, working the garnish side as they are retained by clips. Parts cars provided sufficient clips to restore two car's worth of interior garnish sweeps.
    A touch of contact cement to hold the sweep to the window garnish, install a clip, crimp with vice grips and ..... one done, three to go.
    Super easy. Sorry, can't do the exterior sweeps today....gotta drill out the rivets and then go get more rivets. Can you believe it? I ran out of rivets!
    69598878_2897122213691584_3616413538983084032_n.jpg 69614495_2897122087024930_2229462350203715584_n.jpg 69716839_2897122163691589_213509326864646144_n.jpg
  23. Sharps40
    Sharps40
    Dad,
    Found enough parts to replace broken springs and rebuild the Drivers side window garnish molding and vent wing. Rubber seals look good and I installed the stainless bottom plate. Used stainless hardware to attach the vent wing. Should hold up fine. Just waiting on glass for the vents and front door but proceeding on now to rebuild the Passenger side front door window garnish.
    69784385_2897656940304778_3769053133334904832_n.jpg 69818146_2897657146971424_2842805270873112576_n.jpg 69819864_2897657026971436_7859720483015491584_n.jpg 70225010_2897656840304788_4421855370251599872_n.jpg
  24. Sharps40
    Sharps40
    Dad,
    Passenger side front window garnish and vent wing is fully rebuilt and installed. Fit is very good.
    This was the broken part that I took a replacement into the shop for them to use. They painted the broken window garnish molding instead. In any event, I took parts from a spare window garnish off one of the parts cars and was successful in rebuilding the painted piece. New rubber and window sweep is installed and looking grand. I had to cut the mainspring of an old Mauser Rifle in order to come up with a final spring for the tensioner on the vent window. The Dodge springs are 83 and they just break when you back the clamp screws off.....too old and stiff to flex any more. In any event, this one is up and running and looking fine.
    Next job is back to the back doors. I think the glass is tight in its bottom track. Once cleaned and inspected I'll be getting started installing rear door window sweep on the exterior and putting in the fuzzy channels for the glass to move in. Hopefully this week I'll have all the glass installed except for the Drivers door and both front vent windows (those three are the pieces we had to order.)
    70043474_2897891896947949_416945173008744448_n.jpg 70368575_2897891833614622_5394022514781323264_n.jpg
  25. Sharps40
    Sharps40
    Dad,
    Fitting up one door with window channel. It don't get glued, thank goodness, pinch fit for the back doors. Fronts likely need glued along the top as they stop at the edge of the division bar.
    Grabbed the worst of the unbroken panes of glass to check fit and function, this piece of glass had several gouges in it and a chip.
    Got it all together, working great, (figured out/remembered, on the Dodge you have to install the glass THEN feed in the channel it rides in. What a pain).
    But, put in the last screw, tink, cracked bottom to top. No worries, I have two much newer pieces of glass that match and have no gouges. Also have one more 83 year old piece of laminated glass, also clear and defect free.
    Now to get those pieces of glass on good risers so I can install them.....now that i remember how!
  26. KJSR
    KJSR
    from Utah
    1. Utah HAMBers
    Keep it going man. I will be using this as a reference for my 37 in the spring!
  27. Sharps40
    Sharps40
    I got to get urethane to set the glass in the risers. Also gotta get rivets and put on the exterior sweeps first though. Good lesson tonight. Back doors are a bear sliding the channel down between the glass and the door frame. I think I'll grease it up after the window fuzzies are installed. Might make it go a touch smoother. Looks like the tops of the front door channels need to be glued or taped though since the channel dosn't come back down along the edge of the vent window. I'm liking the tape, probably try it first, easier than the 3m Black goop.
    Also, the window riser button is pressed into the riser channel. I squeeze it with channel lock plyers while prying the lip open with a screwdriver. Once they pop in a touch of grease where the button rides makes it slide nice.
    Cleaning up the old dirty glass with Ajax and 0000 steel wool really brings it back to life.
  28. Sharps40
    Sharps40
    Dad,
    Rear door glass is in and functioning. All external sweeps riveted on. Seals tight. Nothing busted.
    Originally there were no exterior window sweeps, dodge had rubber bumpers in the middle of the door pressing on the outer face of the glass. These prevented rattles but are long rotted away. I'd put sweeps in in the 90s, liked it better for sealing up the door and window. So, did it again here, a sweep inside and outside and no rattles.
    The riser track on the passenger side door was worn. Closed it up as much as i could but the fix to keep the button from jumping out of the track was to bend the riser arm slightly, it pushes the button into the track now rather than pulling it out. Works fine. Just got to let the adhesive holding the track to the glass set for 24 hours and then we should be in business.
    If needed, after the glass runs have set in for a while, I'll glue the tops in place or set them with small sheet metal screws should they look to be loose. But, the originals and the ones I had put in in the 90s were not glued or screwed and never fell out. I suspect the additional efforts will not be needed. Starting front windows as soon as I get the 3 pieces.
    Ol Bessy is nearly buttoned up!
    69590220_2901427583261047_1752490808755355648_n.jpg 69684809_2901427719927700_486883170621325312_n.jpg 69990234_2901427639927708_2559872268729581568_n.jpg
  29. Sharps40
    Sharps40
    20190907_073514.jpg Dad. Glass #8 of 11. 3 pieces to go when they arrive. This is passenger front door. Small strips of electrical tape at 4 locations center the pane. Gorilla adhesive for glass instead of urethane or butyl tape (easier to clean off and edge is paintable to black out the seam.) Clamped lightly to line it up in the bottom of both grooves. Grabs fast so I can pull the clamps and remove the ooze out while soft. I think it'll be fine. Off to inspect the differential now.
  30. Sharps40
    Sharps40
    Dad,
    Not a positraction but still rear gear gold. Made 1970. Chevy. 12 bolt. Low wear. Ratio is 3.31 to 1. So. Itll be perfectly happy with a small displacement small block engine and 3 speed or a torque making 350 chevy and a 4 speed. I couldn't be happier!
