Hot Rods 1937 Dodge Ol Bessy is Coming Home....redux
Discussion in 'The Hokey Ass Message Board' started by Sharps40, Oct 5, 2018.
  1. Awesome! Now the wrenching begins! Thanks for the update Hobo Jim
  2. Sharps40
    Sharps40
    Inventory sat and sun. Call Dad. Finalize the plan and get wrenching. Prolly assemble all the remaining sheet metal and bracketry. Start laying in all the parts in Sept and assembly at the same time. I guess I'll start with.....who knows. But I hope to fire it in October and be driving it by Christmas. Not sure if I'll tell Dad. If i can get it done, I'd like to drive it from NC to VA on Christmass and throw him the keys Christmass eve or day....sort of a total suprise. But we will see.
  3. That would be a Great Christmas gift I wish I was closer I would love to help you reach this goal.
  4. Sharps40
    Sharps40
    I gotta locate and engine hoist here local. I'll get the engine stand from Dad. Once thats done, I think the hard part will be not scratching the paint.
  5. gene-koning
    gene-koning
    So what is the modern motor and trans your pulling out? I may be interested. Please PM me the info. Gene
  6. Sharps40
    Sharps40
    Likely pull the 2007 5.3 LS Truck engine and swap for a non computer, non steam, non pressure vessel, non 40Eleven electrical connector new motor with a warranty. Possibly also the 4l60e as to date, I've read the FiTech programming manual 7 times and I still have no idea which buttons to push to make the transmission work should I decide to retain it! (Basically, I need to call FiTech and if the controller doesn't have a standard shifting map already installed for a plug and play, I doubt my ability to make the driveshaft turn.)
  7. Sharps40
    Sharps40
    Loaded and rolling at 1100. 5 hour drive may arrive tonight
  8. Sharps40
    Sharps40
    Email to Dad.....
    Dad,
    Todays work.
    Got her home and in the garage.
    Front suspension springs are too long, bent and shocks won't fit up inside them.....I'll call Fat Man, may need shorter ones/cut down???....not sure, unsure if this is a screw up by the shop or just and incomplete assembly. Lower A arm bolt on the passener side rests snugly against the boot/end of the power rack.
    Dash is scraped up and needs new paint, probably by the shop in the moving around.
    Headlights are scratched, not too bad though.
    Hood braces installed, hood aligned, hood pins fitted, hood handles adjusted/freed up to operate.
    Door check straps installed, door hinge pins seated.
    Running board brackets installed, running boards need drilled and fitted.
    Headlight stands and trim installed.
    Headlight buckets installed.
    Headlight inserts installed (6 hours to figure it out!!!)
    Front Wing emblem installed.
    License plate installed.
    Screws installed in dash to hold it on, all threads are stripped, will have to repair to hold the dash up.
    67841297_2846738515396621_2886644848171941888_n.jpg 68246550_2846738672063272_670797346728050688_n.jpg 68376247_2846738992063240_5589062666229383168_n.jpg 68625556_2846738722063267_2722153510610141184_n.jpg 69349752_2846738912063248_1767587133469491200_n.jpg 69412008_2846738605396612_8719843110592446464_n.jpg
    Hank37 and chryslerfan55 like this.
  9. Sharps40
    Sharps40
    I think its sitting high in the front and the front springs are too long.....opinions????
    Springs look like ( ) - bow legged- and shocks won't go up inside the passenger side, it will go in on the drivers side but it rubs the spring.
    Cut em? Shorter springs needed/available?
    It has the weight of the v8 and trans on it but still looks too high to me.
  10. Yeah I agree it looks high in the pics. Are you using a stock suspension or a front clip of something else? I am using a S10 front clip and I tried shorter springs. I loved the stance but I couldn’t get the wheel/tire clearance to work. I ended up going with stock height springs it looks good just not as good as it would have if I could have made the shorter springs work.
    Hobo Jim
  11. Sharps40
    Sharps40
    Mi2 suspension. 2 things to fix, springs and PS lower arm bolt is against the boot on the rack.
  12. Sharps40
    Sharps40
    Email to Dad this morning....
    Dad, this mornings work......off to mow and buy bolts to fix the dash attachment.
    Installed the windshield inner trim, installed lower dash bolts (it won't fall out now), found steering column drop, installed rear view mirror, painted and reinstalled the license plate bracket (Silver), installed back seat hand straps and coat hangers, installed dome lamp and dome lamp switch, found and hung the dash plates that hold the light switches, throttle and choke, installed the full filler neck and grommet, located and installed the very poor condition front bumperettes.
    67880844_2848273108576495_5296872888576507904_n.jpg 67929912_2848273171909822_1286461710105837568_n.jpg 68474621_2848272731909866_4091326425297059840_n.jpg 68489087_2848272645243208_245297500808806400_n.jpg 68703883_2848272798576526_7622605315812360192_n.jpg 68752013_2848272525243220_5873865774443003904_n.jpg 68796570_2848273261909813_6543207157322481664_n.jpg 69177310_2848272871909852_8631258070082650112_n.jpg 69390071_2848273005243172_29083121936760832_n.jpg
    The 39 guy and chryslerfan55 like this.
  13. Sharps40
    Sharps40
    Dash is fully secured now, top and bottom. Top screws are stainless with stainless nuts and washers as the windshield opens for ventilation and is subject to water. I have three windshield drains to hook up. Running boards by Smoothie Fab are on. Pretty good fit for 82 year old car and lots of body work. Drivers side is a bit off but i still have front sheet metal to align. Back to front is where it needs to be and locked down snug. These are made for stepping on, top coat is black bed liner instead of the old style rubber mat.
    68680484_2849496525120820_6086084089973047296_n.jpg 68858326_2849496595120813_4692619810922561536_n.jpg 69609088_2849496451787494_7637917853475143680_n.jpg
  14. I like the painted outside edge on the running boards I wish I would have thought of that on mine! Very nice touch! Hobo Jim
    Sharps40 likes this.
  15. Sharps40
    Sharps40
    Windshield glass and rubber are good. Pulling the opener this week. Going to install it and the cowl vent.
    Can vent window wing glass be set in urethane rather than tape? If so might save me breaking 17 pieces of glass trying to rebuild the vents.
  16. Sharps40
    Sharps40
    Dad, tonights work.
    - Glass inventory. Three cars worth will yield 8 near perfect sections of glass of the 11 pieces needed. We'll buy 1 drivers window, and 2 vent wings for the front doors. Savings will be about $700.....don't worry, we'll spend that on rubber!
    - The window crank mechanism in the dash is cleaned, lubed and the zinc gears in near new condition. I have a spare mechanism for parts, and this part is not available at any price!
    - Windshield in good shape, I'd replaced it in 91, and the rubber is still soft and plyable, no cracks, so, cleaning it up and it'll go back on the car this week. Located every screw needed, those hard to find 8x32 dome top tapered bottom screws.....at least the shop kept them in jar in the box, in the trunk!
    - I properly installed the cigarette holder and cigar lighter box, seems the shop forgot the bolts.
    - The cowl vent is rebuilt with its bug screen and ready to install.....However, rather than remove the hinge bolts under the dash, they cut the damn things off. I'll soak them in PB blaster and see if i can drill them out from the underside. If not, i have to remove all the upper dash bolts and rotate the dash down and back out of the way. Galls my ass they did such good work on the car and got lazy with two bolts.
    68516107_2852216274848845_3475103673221120000_n.jpg 68734351_2852216341515505_3507349261182304256_n.jpg 68894929_2852216144848858_9214013144203001856_n.jpg 69084553_2852216204848852_5570186495416860672_n.jpg
  17. Sharps40
    Sharps40
    Dad,
    Tonights work. Rubber for trunk, opera windows, vent windows and cowl vent should be here Saturday.
    I'll start buttoning her cabin up snug, back to front like all the work. So, the first piece of glass is restored. Drivers side rear seat vent window. Frame and paint good, glass tight and the latch is now polished again. Compare to the Passenger side on the right. I have spare frames to replace the missing hardware so they'll stay open when driving.
    Will probably also build the original trunk shelf this weekend.
    And, buttoned up the dash for the last time I think. Here on the underside is the passenger side cowl vent hinge mounting point. they cut the studs off, no way to get to them from the top, but loosening the dash made enough room for the drill the studs came out. It'll be a 3.5 handed job to get the bolts and nuts back in there through the hinge, but i think duct tape and a drop of superglue on the wrench will make it go smooth in such a tight space.
    Finally, the windshield is coming along. I should be ready to prime and paint it in a couple evenings and then hopefully install it this weekend.
    If i get the cowl vent and crank open windshield done sunday, I'll let you know that the innovative MOPAR Bug Induction System is back up and running!
    68562572_2854818331255306_4090339355913093120_n.jpg 68916538_2854818274588645_7580805092064886784_n.jpg
  18. Sharps40
    Sharps40
    Dad,
    As I work on the 37 Dodge, I continue to review the theme, what you might have done with her in the late 50s to mid 60s.
    I think back to your original set up with the flat head six, though you always wanted a V8. Your set up of the six was bored, shaved, split dual exhaust and twin factory 1 barrel carburetors....with that set up, you won a lot of races against more powerful cars.
    Uncle Mike, your brother, did similar things with his Fords.
    So....since the computer controlled engine and transmission is coming out, I'm going to try getting us back in line with the agreed upon original theme.
    Pending some fitment questions from the manufacturer, the photo shows your potential new fuel system. Something an 18 year old could have done in the 1960's. Dual 2 barrel GM carburetors on an original look adapter, because of course, why have one boring 4 barrel carburetor when you can bolt on more!
  19. That looks really cool nice change
  20. Sharps40
    Sharps40
    Yep, just trying to figure if it'll clear a large cap hei with vacuum advance Sent em a message. Don't know if there is a non computer small cap hei, I suppose from Accell, but don't like their stuff. . Would prefer a gm product.
  21. Sharps40
    Sharps40
    Rear vent windows rebuilt, installed and working properly.
    69032063_2862955513774921_4278967447605739520_n.jpg 69366264_2862955453774927_5694518145004339200_n.jpg 69821030_2862955583774914_1745756317215096832_n.jpg
  22. Sharps40
    Sharps40
    Trunk rubber seal installed and Ram Air On Line....
    68634183_2863209893749483_1144030385433214976_n.jpg 69110167_2863209800416159_5085282269631873024_n.jpg 69172843_2863209733749499_3169964861228580864_n.jpg
  23. Dang you are really knocking this assembly out!
  24. Sharps40
    Sharps40
    15 work says to retirement. Then I'll be on it daily. I want to be installing the motor by Thanksgiving and driving on Christmas day.
    I have to set the opera windows. Already cut the first rubber to short!!
    I put in a message to fatman to try to figure out the front springs.
  25. Sharps40
    Sharps40
    Last night I learned the back glass is smaller than the opening. To fit the seal without a gap the rubber has to be cut to fit the opening....not the glass.
  26. Well at least you don’t have to modify the glass. Much easier than modifying the rubber
  27. KJSR
    KJSR
    from Utah
    1. Utah HAMBers
    Man you're kickin butt.
  28. KJSR
    KJSR
    from Utah
    1. Utah HAMBers
    I think all the "small cap" HEI's are aftermarket......
  29. Sharps40
    Sharps40
    Dad....Opera windows are in....harder than I remember.....arthritis fingers...but still doable as a one man job.....trunk shelf is next and gotta buy more rubber for the doors. And just like the old days, Bessy's license plate gets cocked at the drop of a hat.
    osage orange and chryslerfan55 like this.
