1937 CADILLAC LA SALLE INPUT SHAFT COLLAR – NEW
Discussion in 'Parts For Sale' started by KingShift, Feb 5, 2015.
  1. KingShift
    KingShift
    City: Lambertville
    State: New Jersey
    Price: $146
    Once again THE KING COMPANY has come to the rescue. The 1937 Cadillac La Salle Input Shaft Collar is specific for the year 1937 ONLY. These collars are machined out of #1018 CRS, Solid, Round Stock, which makes them much stronger than the original cast iron collars. They have the pocket inside for the cork gasket and you can use a plumber’s gasket or “O” Ring in place of the cork gasket. If your collar is worn, cracked, broken or lost we have the perfect solution. Over the years these collars were lost and people used the 1938-54 Input shaft collar, which does fit but the inside diameter is much larger than the 1937 Collar and allows oil to saturate your pressure plate and disc. We also make the 1938-54 collars, which do not have the inside pocket for the cork gasket. Both cost $146. We also make the pivot ball studs and “C” Clips for the clutch release bearing as well as steel buttons to replace the Bronze button that engages the 2nd & 3rd syncro and a pilot adaptor for the Chevy transmissions. Packaging and Shipping are extra and are provided by US Post or Local Pickup. Please contact Tom King at 1 609 397-0161 or TheKingCO1947@AOL.COM. Will buy or trade for 1949-64 Oldsmobile or 1949-54 Cadillac Speed Equipment and engine parts.
    1937 STEEL INPUT SHAFT COLLAR.jpg 1938-54 STEEL INPUT SHAFT COLLAR.jpg King_Parts_001.jpg
    dwollam and chasmatik like this.
  2. KingShift
    KingShift
    "BACK TO THE FIFTIES"
  3. KingShift
    KingShift
  4. KingShift
    KingShift
  5. KingShift
    KingShift
  6. KingShift
    KingShift
  7. KingShift
    KingShift
  8. KingShift
    KingShift
  9. KingShift
    KingShift
  10. KingShift
    KingShift
  11. KingShift
    KingShift
  12. KingShift
    KingShift
  13. KingShift
    KingShift
  14. KingShift
    KingShift
  15. KingShift
    KingShift
  16. KingShift
    KingShift
  17. KingShift
    KingShift
  18. KingShift
    KingShift
  19. KingShift
    KingShift
  20. KingShift
    KingShift
  21. KingShift
    KingShift
  22. KingShift
    KingShift
  23. KingShift
    KingShift
  24. KingShift
    KingShift
  25. KingShift
    KingShift
  26. KingShift
    KingShift
  27. KingShift
    KingShift
  28. KingShift
    KingShift
  29. KingShift
    KingShift
  30. KingShift
    KingShift
