Auctions
1937-1962 Chevy 216 235 261 Intake manifold alignment ring adapters
Discussion in 'Parts For Sale' started by MotherTrucker, Jun 3, 2017.
  1. City: Phoenix
    State: Arizona
    Price: $35
    A Set of three 1937-1962 Chevy 216,235,261 Custom intake manifold alignment adapter rings.
    Precision machined from 303 stainless steel. Will never rust.
    These rings will allow you to install a "large port" 235/261 intake manifold on an earlier "small port" 216 motor.
    Will also allow you to install an earlier 216 "small port" intake manifold on a later 235/261
    "large port" motor.
    Most of the original era correct multi-carb. speed equipment intake manifolds from the 1950's were produced for small port 216 motors.
    These rings work great in properly aligning & sealing these older original intakes to the later 235/261 motors.
    Most of the new modern reproduction multi-carb. speed equipment intakes are produced with the large 235/261 ports.
    These rings work great in properly aligning & sealing the modern intakes to the earlier 216 motors.
    These rings are NOT correct if you are bolting a 235/261 intake to a 235/261 motor...
    Or you are bolting a 216 intake to a 216 motor.
    Set of 3 rings.... $35 W/FREE U.S. shipping
    PM us for more info. Img_5300.jpg IMG_5297.JPG Img_5307.jpg IMG_5295.JPG IMG_5301.JPG
    John Navarro likes this.
