Technical 1936 Ford front axle ID help
Discussion in 'Traditional Hot Rods' started by monaroau, Dec 4, 2017.
  1. monaroau
    monaroau
    The axle in the pic seems to be a 1936 Ford front axle. There are however some funny things about it that I cant work out.
    The king and perch pin widths tell me its a 36. The perch boss is 2 inches which tells me its a 36. Its wishbone has the spring out front which started from 35 I believe. The Ford logo is on one side of the axle so no question that its Ford.
    The strange parts are the 2 holes each side which are in a factory raised section of the axle. The king pin area is a flat tube with no raised parts top and bottom which I would expect.
    Anyone seen anything like this before?
    PAracer likes this.
  2. Manager
    Manager
    Pilot axle.
    K13 and X38 like this.
  3. monaroau
    monaroau
    Thank you Manager. It does look to be that. I just found this video where you can see the same. So it seems I get a 1936 Ford axle that is at least 10 years younger than its north American cousin.
  4. bct
    bct
    Such a pretty shape.
  5. seb fontana
    seb fontana
    from ct
    What are the holes for? I couldn't see anything mounted in the video..
  6. monaroau
    monaroau
    There are no markings around any of the 4 holes so nothing seems to have mounted there so they must be speed holes.
    ls1yj likes this.
  7. gimpyshotrods
    gimpyshotrods
  8. Fordors
    Fordors
    The OP is in Australia and the language for the intro to the video looks to be from a Nordic country to me. Seems unlikely two cars that far apart would have the same exact holes in their axles.
  9. fiftyv8
    fiftyv8
    from CO & WA
    I think the Pilot was fitted with a front sway bar or whatever they are known as, so it may have been mounted to the front axle at the drilled points
    burtrido likes this.
  10. Manager
    Manager
    I do know the answer but I just can't remember it right now.:rolleyes:
  11. I would have guessed a steering stabilizer mounted to those two holes.
  12. roger didonato
    roger didonato
    Me thinks the same.The front axle of my 36 ute (from oz) doesn't have those holes
