Technical 1935 Wire Wheel Tire Sizes
Discussion in 'Traditional Hot Rods' started by ChopTopJimmy, Jul 10, 2016.
  1. ChopTopJimmy
    ChopTopJimmy
    I'm sure this has been covered before so I apologize for asking again. I have no luck whenever I try to search something on here. I would like to know what minimum and maximum bias ply tire sizes will fit on original Ford 16x4 inch 1935 wire wheels? I would like to run 500/525 front and 750 rear on these wheels but according to the Coker rim width chart, the 4 inch width is too wide for the 500/525 and too narrow for the 750 tire. Any real world experience that you guys could share with me is greatly appreciated. Thanks, Jim.
  2. Hey Jimmy,
    The most effective search method is to type your question into Google and it will come up with a whole heap of responses from the Jalopy Journal. I just did a quick test and typed in " tire size for 35 wire wheels" and got a bunch of hits.
    And yes, plenty of people running 4" wide wires with those size tires.
  3. ChopTopJimmy
    ChopTopJimmy
    DeLuxe, Thanks for the advice. Any idea why Coker says these sizes won't work on the 4 inch wheels? Jim
  4. 1-SHOT
    1-SHOT
  5. ChopTopJimmy
    ChopTopJimmy
    True, guess I should have known that. Anyone running a 450/475 on a 4 inch wide wheel? Thanks again. Jim
  6. <------5.50 front and 7.50 rears. :)
  7. The 500/525 is definitely the most popular front tire size, some run 600.
    And because this thread is useless with out pics...
    ^^^^ 600 on the front ^^^^^
    Scott Mannion and Texas Webb like this.
  8. dumprat
    dumprat
    from b.c.
    I have 5.00/5.25 on 40 Ford 4" wheels. They are stupid looking. Not because the wheel is too narrow but because the tread of the tire is round like a VW tire not flat like a 4.75 or 6.00 tire. Just saying
  9. 6.00s on the front and 7.00s on the back
    Scott Mannion likes this.
  10. Schwanke Engines
    Schwanke Engines
    I have Coker 7.50X16 on rear of my 35 wires and MT90 motorcyclist tires on front. Mounted easily without issues.
    Sent from my XT1585 using The H.A.M.B. mobile app
  11. Hnstray
    Hnstray
    from Quincy, IL
    Yes.......because the tire cross section width of a given tire size maintains the desired shape/profile when mounted on rims of a certain width range. Wheels narrower or wider than those the tires are intended to be mounted on distort that shape/profile. The tire then does not perform as intended by the engineers. Too tall a tire profile on too narrow a wheel also creates cornering loads the wheels were not intended to carry.
    Now, does that mean you cannot mount them on whatever you want! Nope, you can do whatever you want and, in most case, 'get away with it'. As long as you are willing to accept the compromises that result.....which you may not notice. But that doesn't make it right.
    Ray
  12. synchro7
    synchro7
    I'm running 5.50 on 4" and 7.50 on 4.5" x 16" Kelsey Hayes wheels
  13. clem
    clem
    Plenty run them on 4 inch rims and seem to get away with it.
    Fronts will be okay with 450/475 or 520/550 probably ok with 600s
    I would not run 700 or 750 on a 4 inch wide rim, - just too narrow in my opinion, so I widened mine to 6 inch and they seem ok.
    I believe that a 700 or 750 on a 4 inch rim with low tyre pressure could bounce of the rim. - some scoff at this comment.
    Safety first !
  14. Scott Mannion
    Scott Mannion
    from Scotland
  15. dumprat
    dumprat
    from b.c.
    Years off off road use has taught me the opposite is true. Too wide a wheel will loose tires, too narrow will not. A4" wide tire on a 4" wide wheel is a problem a 6" wide tire on a 4" wheel is pretty hard to break loose.
    As a test once we put a set of 15" wide 38's on a stock 6" wide Toyota wheel. Horribly hard to get on the wheels and you could run them with almost no air and they wouldn't unseat the beads.
  16. G V Gordon
    G V Gordon
    from Enid OK
  17. Muttley
    Muttley
    This one belongs to my Dad, it's got 5.50's on the front and 7.50's on the rear:
