Technical 1935 Ford w/power brakes question
Discussion in 'The Hokey Ass Message Board' started by gearheadbill, Jul 24, 2018.
  1. gearheadbill
    gearheadbill
    There are so many really good mechanics here on the HAMB that I can't think of a better place to ask. Hopefully this is not so o/t that it gets bounced. I'm not looking for text book technical info; just practical. I've never had an old car with power brakes before, so this new for me.
    I have a 35 Ford resto-rod with modern power assisted brakes. The system has a small brake booster under the floor, a reserve canister between the intake and booster and working check valves. The car has a mild SBC that has 11hg vacuum at idle/in gear, 14hg in idle/park but will run up to 22hg under throttle then back to around 14hg when decelerating. My understanding is that 18+hg is needed to effectively utilize the booster.
    To my simple brain the reserve canister should store vacuum like a compressed air tank, only negative air pressure (suction) rather than compressed air pressure and the vacuum should be able to be stored/replentished. If not, what the heck good is the reserve can? The motor make plenty of 18+hg vacuum, just not all the time. Why won't the reserve canister store the highest level of vacuum?
    I hope this description makes some sense. Thank you. View attachment 3978522
    Casey Riley and chryslerfan55 like this.
  2. ford40
    ford40
    from pa
    Why do you need a reserve canister? there is a check valve in the booster.
  3. 54vicky
    54vicky
    those vacuum #s seem low that may be the problem.if it has mild cam should be higher
  4. 35WINDOW
    35WINDOW
    Apparently you are having issues-what are they? From what I've seen, a Canister will store vacuum, but will work for only a stroke or two before it is depleted-
    I have a '35 too (with Disc brakes and a 7" dual diaphragm Booster)-my engine does not make enough vacuum either, so I went with an electric vacuum pump (a Hella UP30)-they are made for electric cars, although they are also used on Ford Mustangs (Cobras),Ford Diesel Pickups, Volvo and a host of other cars-look on Ebay under electric vacuum pumps-there are a bunch-if you do this, pair that with a regular vacuum pump shutoff switch-hope his helps-
