SOLD !!! here's a set of rather nice 35 ford pu headlamps. I've used these headlamps on the last 3 TRADITIONAL Hot Rods I have built. They give your HOT ROD a cool traditional hot rod feel... these have not been modified , but are complete and all original , if you wanted to convert to 12vt, speedway and others sells a neat halogen kit to convert the reflectors , also, if you want to use these on model A or 32 headlight stands (or aftermarket head light stands) you will either swap the perch bolt or open up the size of the hole in your stands ,easy to do either way, however I prefer swaping the perch bolts for smaller diameter. really nice condition, one ring has a slight character imperfection(not what your seeing in the pic, the gap between the lens and ring is because the lens isn't positioned correctly due to spring retainer. $200.00 firm plus shipping and I will be very carefull with the packing, [email protected] shown below are 3 examples where I have used these same headlights to give you an idea how killer they look I haven't disassembled the lens ,so there is still cleaning needed on the inside
