I have a 35 Ford pick up project. Super solid cab for a 35, with all the garnish moldings. Body is channeled about 3" over the frame. The floor are cut out and need to be put back in. I have an un-assembled bed, its not an original type, but is made for a fenderless pick up. Frame has raised front and rear cross members and is notched in the front for the spring. Old 3" drop axle with uncut 35 wishbone, rear end is a 42-47 with 3.78 gears. Tires are new with 6.00x16's on the front and 7.00x17's on the rear. I have some other misc parts that go with it, headlights and steering box and column. Nothing is bolted down, so you still can build it the way you want. Clear WA title in my name. 509-449-0488
