Customs 1935 - 1936 Ford tail light differences
Discussion in 'The Hokey Ass Message Board' started by ab_51Ford, Jan 3, 2020.
  1. ab_51Ford
    ab_51Ford
    So I'm looking for tail lights and stands for my '36 slantback and im lost on em. It's one of those things where you didn't even realize there was a difference until you drag home a project and start getting into it. So.. which tail light stand is which and which model do they fit??
    Thanks
    - Andrew
  2. alchemy
    alchemy
    Those are not tail lights. Those are tail light STANDS.
    35 and 36 had totally different fenders. The 35 had a concave shape back there, and 36 was convex. Not sure if the coupe/roadster stand was different than the sedan stand, but someone will probably have that info for you soon.
    LOU WELLS likes this.
  3. TagMan
    TagMan
    First pic of the "stubby" stands is '35, the other two pics are '36
    5window likes this.
  4. ab_51Ford
    ab_51Ford
    Why did '36 have 2 different lengths?
  5. TagMan
    TagMan
    Don't know if they did, but I don't think so.
  6. 35cab
    35cab
    I think trunk back/touring sedans had longer stalks.
  7. 35cab
    35cab
    A pair of touring sedan stalks/lights on my 35 cabriolet. thumb_IMG_5314_1024.jpg
  8. There were at least 3 different tail light stand lengths for 1935-1936 fords, coupe, sedan, convertible sedan. 1935 Ford tail light stands have bead around the mounting surface, 1936 tail light stands do not. it is more of a sharp edge.
  9. Hnstray
    Hnstray
    from Quincy, IL
    Nice looking car. Curious to know about the rumble seat step pads on your taillight stalks. If they are touring sedan, a 4 door if I understand correctly, it seems it would not have needed the pads. Are your stands modified to add the pads?
    Ray
    Stogy likes this.
  10. uncle buck
    uncle buck
    Actually the first and third are both 35 stands. Only the middle pair are 36. While the third picture looks similar to 36 , they actually are for a 35 sedan with a trunk
    Stogy likes this.
  11. TagMan
    TagMan
    Stogy likes this.
  12. 35cab
    35cab
    Hi Ray,
    You are correct, I modified a drivers side to accommodate a threaded plate to accept rumble step.
    Being a drivers side it needed a little bit of reshaping plus a slightly modified gasket on the base where it meets the fender.
    In hind sight I could probably grafted the touring sedan long stalk on to a regular base.
    The long stalks are not to everyones taste, I may even change them someday but for the moment they are staying.
    I stole the idea of using these from Spence Murray's 36 roadster.
    Gordon.
    Stogy and Hnstray like this.
