1935-1936 Ford pickup tech for the masses
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jan 18, 2008.
  1. Roothawg
    Roothawg
    Not that I have ever seen.
    Loudpedal, I have never tried swapping the doors. Sounds like Blue 49 may be your man for that. I was wondering about body lines etc.
  2. PVCEROD-
    The overall dimensions for the 35 and the 36 are exactly the same. Both years used the same bed and the same frame. The only dimensional differences between 35 and 36 that we know of, covered in this thread, would be the thickness (depth) of the front grill. The hood sides of both trucks are different in design but dimensionally the same and interchangeable with one another.
  3. pvcerod
    pvcerod
    from Australia
    Thanks Fella's for that info......do you know of any Specs / Measurements of the 35/36 bed so I can make one.:cool:;)
  4. jj mack
    jj mack
    You should be able to "scale" it off the drawing roothawg gave you. Also you can get some measurements of the Mack hills website. Look the tailgate, bedsides, front, etc. And use there measurments to come up pretty close to what you need.
    Make one out of cardboard first....see it you like it! The best part of building one is to build one that is in proportion and looks right for your truck....while still looking appearing to be original!
    jj
  5. losdiablotejano
    losdiablotejano
    I am looking at replacing the firewall on my 36 ford pickup and came across a firewall for a 36 ford sedan. Does anyone know if the firewalls on the pickups and the sedans are interchangable?
    Mike
  6. pasadenahotrod
    pasadenahotrod
    from Texas
    Good information BUT to be correct for technical purposes Ford uses the term "Commercial" to include Pickups, Panels, Sedan Deliveries, Station Wagons, and flatbed vehicles 1/2 ton and under.
    Those vehicles above 1/2 Ton in capacity are called in Fordspeak "Trucks".
  7. 36rustrod
    36rustrod
    What happened to those cab mount measurements?
  8. hermn8r
    hermn8r
    Any idea when we will see the cab wood measurements?
  9. cvstl
    cvstl
    from StL MO
    1. H.A.M.B. Chapel
    Cab wood patterns are done, PM me if you want a set. I will try to post PDFs, but they will be hard to use. Best thing will be for me to mail full sized dimensioned drawings and you can use them for patterns.
  10. Redbows35panel
    Redbows35panel
    Well, if your info is correct. My 35 panel has 36 doors. It's got the pull slots in the sills.
  11. Roothawg
    Roothawg
    Redbows, it could be late 35.
  12. 1930roadster
    1930roadster
    Great info!, all i have to do is find one*sigh*
  13. 1930roadster- Just check Craigslist once a week. Actually use www.craiglook.com to search all the craiglists across the country. There are a lot of 35 and 36 p/u's for sale out there.
  14. JeffCTN
    JeffCTN
    This is great.
  15. 51 mercules
    51 mercules
    Great info.Thank you.Here's a pic of my 35 project
  16. case12
    case12
    I posted this on the 35,36 truck flathead group page as well. I have a dilemna. Where the accelerator linkage comes through the firewall, there appears to have been a bracket holding it to the firewall. Mine is not like a typical 32 ford where the linkage bolts directly to the firewall. Does anyone have pics or know what this bracket is? Is it different from the 36 cars? Thanks, Casey
  17. johnhans
    johnhans
    from MN
    Could someone help with the wood dimensions for cab mount on 35 Ford pickemup.John
  18. lonewolf
    lonewolf
  19. howco
    howco
    Root, I am building my first 37 Ford truck and am looking for a grill shell, now I feel a bit more comfortable.
    Thanks
  20. Lawson Cox
    Lawson Cox
    The number of louvers on the 35 and 36 are different
    The 36 had a stiffener bead around the louvers where 35 did not.
    35 louvers had a dip in the center to accomodate the hood side emblem.
  21. Roothawg
    Roothawg
    Hi Lawson, welcome back.
  22. JoeySwass
    JoeySwass
    I need some help:
    Will a 35 hood fit on a 37?
    I have a 37 that I want to use a 35 grill on.
    Thanks
  23. SOCAL PETE
    SOCAL PETE
    from Ramona CA
    I don't think so. The 35 cab where the hood fits is different.
  24. the length is different too...
    but I don't remember the numbers right now.
  25. JoeySwass
    JoeySwass
    I figured so...thanks guys.
  26. Coke-bottle
    Coke-bottle
    Great thread. Actually I only have the '36 firewall, but I consider it a project..
  27. pvcerod
    pvcerod
    from Australia
    But what about cutting & shaping the 37 Bonnet to suit the 35 Grille.
  28. JoeySwass
    JoeySwass
    Thats def. an option I was considering. I was just hoping for an easy fit without the work! If I do it, I will post pics.
  29. B-2
    B-2
    from Conroe,TX
    I am looking for parts for a 36 Ford Pick-up for a Buddy over in England. The bed is not that great we have been looking at Howells Sheetmetal co. They don't have a bed for a 36 but they do have them from 38 on. My ? is can he make a 38 bed fit on a 36 with out to much work. I am not sure if the wheel base is the same or not. If it will only hang over the back that would not be that bad.
    This is a great thread I spent some time reading most of it, I have a 30 Model-A & they are not the same animals. Thanks Bill
  30. big bad john
    big bad john
    ........Thanks for the great thread.....I have a 36 with 35 grill.......put 34 headlight stands on to lower the lights........learn a lot of you.....thanks.....Big Bad John
