I just bought a '34 Plymouth coupe that is in need of some parts. Trunk lid or just the outer skin, grill shell & grill, windshield frame & seal, hood, garnish moldings. This is a fenderless hot rod project so the parts don't have to be perfect, just repairable. Does any one have any contacts for parts? I have searched all over the internet but have found little. Any help would be appreciated.
Like others have said, it's tough finding parts for 33/34 plymouths. Here's a coupe that rolled throughout shop. It took several weeks to hunt down the correct ignition components.
The original post is a couple of years old. Not sure if captainflight ever found the parts needed. I have been helping a friend and HAMB member notaford1 with his 33Plymouth build. http://www.jalopyjournal.com/forum/threads/uncle-ricks-33-plymouth-project.680682 / We started with several cut up pieces of a coupe. It has taken quite a few years and we have often changed direction as we came up with steel parts to replace the fiberglass ones we were originally planning to use. Our trunk lid was a rotted disaster. It took a lot of time and patience. If you check out our build thread you will see that we were able to save it.
