Hot Rods 1934 pick-up : which is longer, a 4 cylinder or a V-8 ?
Discussion in 'The Hokey Ass Message Board' started by steve hackel, Sep 20, 2023.
  1. steve hackel
    steve hackel
    I have a 1934 pick up that is a factory 4 cylinder and I have considered doing a later 8ba
    engine swap (engine just completed by Dennis Frings) and would like to know the
    over all difference in engine lengths? I have a rebuilt 39 trans that can be used with either of the engines ( I have the 1939 style Clings adapter for the 4 cyl ) other rear ends too.
    I can also look into one of the Corn Huskers T-5 adapter kits by Krylon if that would
    help in a conversion.
    Since these were offered in both 4 cylinder and V-8 versions, what might I need to look
    for or modify on the frame & mounts if I decide to go that route in the near future.
    Thanks for any help on this one. ;)
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    I know @krylon32 has created a lot of 1932 truck adaptations. But with the extended firewall on the 34 he may not be able to help.
  3. studebakerjoe
    studebakerjoe
    4 cylinder is longer. The 4 cylinder driveshaft is shorter than the V8 shaft.
    Pete Eastwood and 51 mercules like this.
  4. chevyfordman
    chevyfordman
    So to install a V8, you need a longer torque tube and the engine will have to be raised with adaptors.
    Rj27buick and 51 mercules like this.
  5. BJR
    BJR
    If all 32 Ford passenger car frames are the same, and the rear of the transmission is mounted to the K member, how can the driveshafts be different between a 4 cylinder and a V8.
  6. 1935ply
    1935ply
    from peyton,co
    1. H.A.M.B. Chapel
  7. studebakerjoe
    studebakerjoe
    @BJR the op is talking about a 34 not a 32. On the 33-34 the transmission mount goes on one way with the 4 and turned around the other way with the V8. That allows the transmission to be moved rearward slightly for the length difference.
    Squablow and BJR like this.
  8. BJR
    BJR
    Thanks for the clarification.
  9. studebakerjoe
    studebakerjoe
    No problem. I often wondered why they didn't just do something with the front cross member to allow the 4 to mount slightly forward vs the V8 so there would be no need for different shafts.
  10. steve hackel
    steve hackel
    without getting too deep into the theoretical differences between the 2 engines yet,
    what would be the issues of mounting up the V8 and trans to the 4 cylinders torque
    tube & rear end? Other than the engine being closer to the firewall and possibly not
    having enough clearance, everything else should be fine? If the fan was farther
    away from the radiator then couldn't it just be extended?
  11. alchemy
    alchemy
    Theoretically.
  12. Petejoe
    Petejoe
    from Zoar, Ohio
    The 8ba’s distributor location will be also be a factor on location too as opposed to an earlier flathead.
    The distributor pushes the fan location toward the radiator.
  13. If it was me, I would keep the 4 cylinder. I would get one of the high compression heads from Tod over on fordbarn for a little extra pep. I would send my transmission case to Mac VanPelt along with the complete 39 transmission and have him swap gears. It is not completely straightforward but is doable if you know what you are doing. There may be a little grinding on the case to clear the cluster gear and a sightly different assembly procedure. I would return the adapter to Cling for two reasons. First, I like original Ford parts. Second, I don’t see any place to attach the engine steady rods to the adapter. This might be a good excuse to ask them to take it back. If you decide to convert to the V8 here are a few things to keep I mind. Depending upon how authentic you want the truck to be you can ignore some of the comments. I make reference to’32 because that is what I am familiar with and make some assumptions based on that.
    Of course engine, motor mounts
    Muffler and exhaust system before muffler (same after)
    Radiator
    Radiator support rods (the 4 cylinder and V8 roads were different lengths on the ’32 so you might want to check)
    Engine steady rods (the 4 cylinder and V8 roads were different lengths on the ’32 so you might want to check)
    Hubcaps
    Accelerator linkage
    Engine splash pans
    Gas line needs to be routed from right on 4 cyl to left side on V8
    Need to add V8 emblems
    Need to accept the fact that the serial number (VIN) is for a 4 cylinder
    Charlie Stephens
    51 mercules likes this.
