Projects 1934 Ford Sedan Gender Reassignment Surgery
Discussion in 'Traditional Hot Rods' started by flatnasty, Jan 14, 2014.
  1. BAD ASS!!!!!!!! The profile with rolled out is perfect. Well done keep the updates coming and I love the wheels.
  2. Very crafty dude!..... the car is looking great man I think it sits just about perfect ..... I think I should come over and check it out for inspiration\ motivation to git goin on my lump!
  3. flatnasty
    flatnasty
    from Vancouver
    Thanks John! come by anytime.
    I got a couple Solid days in on the old hot rod this weekend. I decided to keep drudging through the work on the trunk. The rear below the decklid panel was in tuff shape, rotten here and there and pretty crusty all round. So it had to come out. the Vertical triangle supports for the drip rails were rotten and the panel that the decklid latches to was smashed and rotten. Every single screw was broken off in its hole as well. I doesn't look like I did much but what a tedious fuck around. Glad it's Done.
    Brad IMG_20141108_133944.jpg IMG_20141108_112603.jpg IMG_20141112_203847.jpg IMG_20141112_203941.jpg IMG_20141114_124238.jpg
    kiwijeff, Pufff, bct and 3 others like this.
  4. thunderbirdesq
    thunderbirdesq
  5. #FO
    #FO
    from sweden
    Such a badass car! Great job!
  6. pumpman
    pumpman
    It's work like this that makes the car, nobody will see it but you know it's there and done right, Great job man.
  7. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    This is awesome!!! I can't believe I missed this thread! I did the same rear crossmember treatment on my '33.
  8. flatnasty
    flatnasty
    from Vancouver
    Thanks Fellas!
    I have been really struggling with the look of the car from the rear. It pretty well looks like an unfinished hunk of shit to me write now. The rear cross member seems to be the root of the problem. It looks like shit. I don't want to run a stock tank and I`m not into the kick the rails up to fallow the rear body line and put the spreader bar on with a push bar. That Reminds me of a trailer Hitch. So I`m thinkin Roll Pan to clean it all up.
    I ended up using the front header off that 39 ford sedan roof skin that I cut up for my roof insert and deck lid skin. It`s peaked in the centre witch didnt work for me but it`s way too wide as well so I just cut the peak out. Then spent an eternity trimming and lining it up. In the end it sure cleaned up the back of the car. Now I just need to lop off the rails flush with the cross member and figure out how to transition them into the body.
    Brad
    IMG_20140908_204752.jpg IMG_20141114_164905.jpg IMG_20141114_170041.jpg IMG_20141115_150823.jpg
    kiwijeff and Pufff like this.
  9. manyolcars
    manyolcars
    what will you do so that your new part doesnt fill up with dirt and gravel?
  10. 53chevtrev
    53chevtrev
    from Langley BC
    Looks good brad, ever thought to louvre the roll pan to match the trunk lid? Keep it up man!
  11. 39 four doors are good for lots of stuff I see.
  12. Very impressive if I do say so...Looks KILLER from the back now....No longer like shit.
  13. flatnasty
    flatnasty
    from Vancouver
    Work on the old hot rod continued this weekend. I started off by changing out my torque tube. The torque tube I had in the car was a 4 cylinder one. As you can see they are shorter and don't work if your running a v8. My orig plan was to shorten my 39 but I was able to find a 34 v8 one so I opted for that. heres the difference. IMG_20141205_164654.jpg
    To put a 34 torque tube on a 39 banjo you have to die grind the end so it will fit.
    After that I got to work on finishing up the rear x member. Trying to get it to transition into the body smoothly without looking so unfinished and goofy. Some pie cutting and adding a piece to the inner wheel well to drop the roll pan took care of that. IMG_20141212_122726.jpg IMG_20141212_125615.jpg IMG_20141212_145614.jpg IMG_20141213_134723.jpg
    Brad
    kiwijeff, ls1yj, Pufff and 1 other person like this.
  14. ss34coupe
    ss34coupe
    Brad - you are doing a lot of innovative stuff here. I've said it before, you are doing a great job with this build! Steve
  15. Outback
    Outback
    from NE Vic
    Thats looking great! A real inspiration!
    Sent via carrier pidgeon & smoke signals with the HAMB App
  16. flatnasty
    flatnasty
    from Vancouver
    Hey fellas
    When I did the first cut on the top chop for the old girl a couple friends came out to lend a hand. fellow hamb member harveymushman Happened to catch some of it on video. He sent one of the clips over to me so I thought I'd share.
    Thanks A lot Brian!
    Brad
    Pufff and mauler rich like this.
  17. flatnasty
    flatnasty
    from Vancouver
    Here's a couple more top chop clips.
    Pufff likes this.
  18. rat nasty
    rat nasty
  19. flatnasty
    flatnasty
    from Vancouver
    Continued work on the floor of the old hot rod this weekend. Rolled some beads in the front half floor pan. It was awkward as fuck trying to hold that big panel and roll the beads by my self. So they aren't perfect. But not bad either. Then I fit it and welded it in. I'm feeling a light at the end of the tunnel as far as the sheet metal work is concerned.
    Brad IMG_20141003_182505.jpg IMG_20141213_221739.jpg IMG_20150104_161603.jpg
  20. Fordgasser1
    Fordgasser1
    from Jersey
    Nice job on those floors! Looking awesome!
  21. The floor looks great. Must of been one hell of a trick trying to roll those beads by yourself, bravo.
  22. X2 :D
    how deep was the bead roller? that's 2 pieces (l&r) along the drive shaft tunnel right?
    I hope you took some pictures of that one.
  23. ss34coupe
    ss34coupe
    Floor looks good. What gauge metal did you use?
  24. flatnasty
    flatnasty
    from Vancouver
    Thanks Fellas
    I used 18gauge
    It was just one big piece. I used my new Baileigh 36" power bead roller, with a little planning there was no need to cut it. IMG_20140606_155825.jpg I step rolled the centre so the flange on the tranny tunnel sits flush. Then I plug welded it in the car as one piece. After I got it in the car I plug welded the tranny tunnel in. then I cut the strip out from under the tranny tunnel. I figured it would be easier that way than trying to hold and align all the pieces separately.
    Brad
    kiwijeff, wedjim and mauler rich like this.
  25. Robert Crosse
    Robert Crosse
    from WNY
    I like your helper...."what's next Dad?"
    mauler rich likes this.
  26. flatnasty
    flatnasty
    from Vancouver
    IMG_20150110_141928.jpg IMG_20150110_133455.jpg IMG_20150104_145500.jpg IMG_20150103_203641.jpg IMG_20150103_121609.jpg IMG_20150103_112310.jpg IMG_20141227_152308.jpg IMG_20141115_163045.jpg
    Back to work on the coupe this weekend and last. Started clawing my way through finishing the trunk. The trunk lid ruffly fit the opening when it was set in there so now it's a matter of getting the hinges working and getting it fitting and swinging. I only had one of the orig blocks that the hinges attach to on the car, so a friend of mine cast me one up off the orig.
    After that was ground out and looking half ass I directed my atention to the rotten drip rail on the top opening of the decklid.
    I was able to find a orig one to repair the rotten one.
    After that I fixed up the rotten quarter pannel braces.
    Now all thats left is a bit of decklid repair and final fitment and get the latch working. that should only take like 20 hours. lol
    kiwijeff, Pufff, wedjim and 1 other person like this.
  27. ss34coupe
    ss34coupe
    Good to see you are back at it! Gives me some inspiration to get going on my coupe.
  28. flatnasty
    flatnasty
    from Vancouver
    IMG_20150221_221738.jpg IMG_20150305_225748.jpg IMG_20150228_182445.jpg Got Back to work on the old coupe this weekend. I spent all day friday Fucking with the deck lid, trying to get it lined up, swinging and latching. I was alot of pissing around but she's all done. Saturday I made a crossmember hump and the interior cover pannel for behind the below the deck lid pannel. I Got it all done. Finally the trunk is done aside from mounting the gas tank and tail lights.
    Does anyone have any good ideas for tail lights? I want to keep it pre 41.
    Sunday I picked up a 41 lincoln overdrive tranny that I have some plans for with this car as well. you'l have to wait and see what happens there and so will I for that matter lol.
    Pufff and Fordgasser1 like this.
  29. deathrowdave
    deathrowdave
    from NKy
    39 Chebbie tail lights
  30. Roger53
    Roger53
    You're doing one bang up job on old gal. Roger
