I am selling my frame complete with the motor, trans and rear end. This is an original frame, boxed in the front with a mustang ii front suspension, complete with the rack and pinion, steering column, u joints and shaft, and steering wheel. Also the disc brakes. The engine is a great running and driving 350 chevy with all accessories, air compressor, alternator, starter, carb and fuel pump, distributor and everything associated with it, including the 350 trans. Also the 9 inch ford rear end, equipped with wildwood disc brakes and leaf springs. All the exhaust, headers, mufflers and tail pipes. You can take this complete setup and bolt a body on it, and be running instantly.
