1933-1934 Ford chassis only. Body, wheels, motor, transmission NOT FOR SALE. Original 33-34 frame. Front half boxed, Vega steering box, center transmission mount removed, stock rear crossmember. Frame has typical rust issue where x member meets outer frame rails. Dropped and drilled heavy axle. Round back spindles, split 34 wishbones, stock front leaf spring S.S tie rod and drag link. Chassis Engineering bolt in parallel leaf spring kit with ford 9 inch rear end. Front motor mount is set set up for a Hurst style mount. $5,000 located in Englewood NJ
