Technical 1934 Ford Coupe Rearend Advice
Discussion in 'The Hokey Ass Message Board' started by Pitbullgoingpostal, Apr 8, 2021.
  1. Pitbullgoingpostal
    Pitbullgoingpostal
    Can one of you experienced HAMBers give me a realistic idea of how much spacing is required from the top of a rearend to the bottom of the frame rails? Keep in mind my car has no weight on it other than the weight of the frame at the moment.
    I should mention I’ll be using ‘36 radius rods (with torque arm, or arms) and a straight spring. Meaning, I’ll have to fabricate a new rear crossmember. That’s why I need a close measurement for decent clearance once the car is built.
    If I can attach a pic for good measure (no pun intended) I will. Thank you so much. Britt IMG_5426.JPG IMG_5425.JPG IMG_5424.JPG IMG_5427.JPG
  2. Weedburner 40
    Weedburner 40
    Generally, we set rear clearance at about 3" at ride height.
  3. rusty valley
    rusty valley
    my 34 sits about 2" from the rubber pad. not enough as it will bottom out occasionally. Yet, with 750x16's on it, the ass is high. 8 leaves in the spring if i remember correct
  4. I agree with weedburner, about 3" should be good, you may want to C notch the frame and/or cut a spot in your floor pan to let the pig ride up and clear your floor. Depends on how low you want the rear/wheelwell reveal to sit. I am running PJ ladder bars and an 8.8. Your work looks great. Have fun with your project.
  5. Do a upper torque arm from the axle tube to the point where your radius rods mount.36 Bones werent intended to fight twist.If you used a N carrier........you plan on twist.
