Technical 1934 Ford 5w glass patterns
Discussion in 'Traditional Hot Rods' started by 19-c, Jan 23, 2018.
  1. 19-c
    19-c
    just wondering if anyone out there has window glass patterns for a 34 ford 5 window. Stock unchopped.
    Thanks
  2. sloppy jalopies
    sloppy jalopies
    when you get the patterns and cut the glass be sure that it sets in the steel channel in exactly the right spot as the steel edge can hang up on the offset felts... upper rear felt is much wider, lower front felt is the same.
  3. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    You should check out Montana Shower door in Billings. Highly regarded and has patterns for most vintage cars. Goes by Glassman here on the HAMB. Look on the Hamb O'Dex listings.
  4. here is some of his for a 50 Buick convertible he's done 8 cars for me now always happy
