Technical 1933 Plymouth rearend
Discussion in 'The Hokey Ass Message Board' started by Rich s n, Feb 3, 2020.
  1. Rich s n
    Rich s n
    Can anyone tell me What rearend can be used on a 33 Plymouth deluxe So I can get away from the key way and the drum hub style Or any info on if u can swap maybe the axels to go reg drums
  2. Moparfun
    Moparfun
    why do you want to change ? I've got a 50 and drilled out the drums and put studs on and now running American Torq Thrust
  3. Rich s n
    Rich s n
    Because it’s next to impossible to find drums
  4. anthony myrick
    anthony myrick
    Ford maverick.
    It’s even the correct bolt pattern.
  5. I used a '58 Ford car rear(9") for my '34.
  6. lemondana
    lemondana
    from Lincoln NE
    A 1973-1976 Mopar A Body {Duster-Dart} 8 1/4 rear. 4 1/2 bolt pattern and supposedly the right width. Make sure it's not the little 7 1/4.
    31Dodger likes this.
  7. Fat47
    Fat47
    I've put a 8" Ford under my 33 Dodge coupe . Fit perfectly.
  8. lemondana
    lemondana
    from Lincoln NE
    My first car was a 1968 Cougar XR7, 302-2bbl and a C4 auto. It had the 8 inch rearend. I went through 6 or 7 pumpkins, So in my book I will never use an 8 inch under anything!
  9. Baumi
    Baumi
    I had a S10 10 bolt in my 34 Plymouth, worked great!
  10. plym_46
    plym_46
    from central NY
    Early Cherokee or early 5 bolt Dodge Dakota.
  11. abe lugo
    abe lugo
    There is a conversion to model A drums on ply33.com if you want to keep it original. You just need the puller tool to pull them off. The real trick is to know how to adjust early brakes.
    Apparently changing to the later 60’s mopar 8 3/4 gets you the drums and a better ratio for highway driving Also you can also go to rear hand brake.
    O yeah and on the mopar rear you can use the factory leaf perches. It is literally bolt in.
    kidcampbell71 likes this.
  12. southcross2631
    southcross2631
    My brother used a 69 Nova 12 bolt in his 34 Plymouth. Been in there since 1970.
  13. derbydad276
    derbydad276
    XJ Jeep Cherokee they made a million of them
  14. Gman0046
    Gman0046
    I used a 10 bolt Nova rear end in my 33 PD coupe.
