Projects 1933 Ford Truck
Discussion in 'The Hokey Ass Message Board' started by Steve Hurst, Sep 17, 2019.
  1. If you’d pull/push it up it would fix the gap too.. however you may have to lower the whole shell
  2. Steve Hurst
    Steve Hurst
    No filled holes for the stainless trim. I’m scratching my head also. Everything I read says it’s a 33 shell but it doesn’t fit.
  3. Steve Hurst
    Steve Hurst
    The hood sides line up with the fenders like they should. If the cab was to or down the sides would be off.
  4. continentaljohn
    continentaljohn
    I think the cowl front is a bit low exaggeration the front of the hood . Hows the spacing on the bottom of the hood
  5. Steve Hurst
    Steve Hurst
    I see what you are saying. I may be able to bend it back but I’m not certain. As bad as it’s been hacked maybe I’ll try to find a different shell.
  6. That one will never fit as it is.
    Maybe someone stood it up like 32 and pushed it down cuz that peak would have been standing really proud
  7. Try a gentle squeeze or push at these points
  8. clem
    clem
    Looks to me like the grille and front of hood needs to be higher.
    Also noticed that where hood meets cowl, the hood is out of shape. Fixing this will probably help the other problems.
    May also be out of shape at front.
    Is that a ‘32 grille surround ? Looks like it should be straight up to make the top correct.
    Sometimes it takes a bit/ lot of tweaking.
    Swage lines from cab to hood should be straight, when viewed from the side.
    Can you get any photos from further back ?
    loudbang and catdad49 like this.
  9. Steve Hurst
    Steve Hurst
    The line at the cowl is acceptable. As well as the line at the bottom of the hood sides.
  10. Steve Hurst
    Steve Hurst
    I’ll get more pictures tomorrow. Thanks for everyone’s input. The help is greatly appreciated
  11. irishsteve
    irishsteve
    Could it be the curve in the hood has flattened out? With the sides off you may have to roll it on a gas cylinder to narrow the front,,and bring the edges back in.Also unbolt the cab,and shift it to see if its a bit crooked on the frame.
  12. Corn Fed
    Corn Fed
    I agree with 31 Vicky....the top of your shell is pushed down and the edges need to go in. You might have to remove whatever is welded into the old rad cap hole first.
    31Vicky with a hemi likes this.
  13. Not sure that's a 33 ford pickup radiator shell.....is a big truck hood or radiator shell different? Almost appears too big to me.
    loudbang and continentaljohn like this.
  14. clem
    clem
    Wondered if you actually have a ‘32 grille.
    20339325-068A-42D6-988D-F97BB4F99FC4.jpeg 31E81F67-9789-4BE6-A645-76290562EDF4.jpeg
    Notice the curvature of the hood, where it meets the cowl, especially on the 33/34 above!
  15. brigrat
    brigrat
    from Wa.St.
    Floor was missing?
    Do you have your sub rails installed properly and the wood body mounts in place?
    lothiandon1940 likes this.
  16. Is it possible to take a full profile picture too ? The whole truck side. Maybe even firewall, and the floor repair pictures ... inside the truck ?
    loudbang and lothiandon1940 like this.
  17. Petejoe
    Petejoe
    from Zoar, Ohio
    Yes that is definitely not a 33 truck grill shell.
  18. Steve Hurst
    Steve Hurst
  19. clem
    clem
    Front of hood still needs to come up.
    or front of Cab needs to come down.
  20. Steve Hurst
    Steve Hurst
    yes, the whole floor was missing. the floor has yet to be replace but the cab is mocked up where it needs to be., or really damn close. I understand that affects final alignment issues but the grille shell alignment is my concern at the moment. It doesn't matter if its all hanging in mid air. If the lines on the grille shell don't match the hood it is between those two pieces. I'm with 31vicky right now, I think the top has been smashed down.
    kidcampbell71 likes this.
  21. Steve Hurst
    Steve Hurst
    if I raise the front of the hood or lower the front of the cab it throws off the hood side to cowl line or the hood side to fender (frame) line.
  22. clem
    clem
    ^^^^^after having got the curvature correct first, as per my comments on post 38 & 44.
  23. oldolds
    oldolds
    The top center of the grille is pushed down, at the edge by hood. That is pushing the corners out. Push it up and the corners will come in.
    Steve Hurst likes this.
  24. clem
    clem
    I see now what 31 vicky was getting at. He may be right.
    Hard to tell from the pictures as the top of grill surround has been modified.
  25. manyolcars
    manyolcars
    T
    Came here to say this. Your radiator shell is deformed
  26. catdad49
    catdad49
    I thought he was working on the front!
  27. .........I'm easily distracted!:D;)
    catdad49 likes this.
  28. Deuce Lover
    Deuce Lover
    The shell he has looks like a '32.'33's and '34's are slanted and interchange
  29. Shutter Speed
    Shutter Speed
    Changing body/hood position will make no difference...that shell is touching the hood top center AND bottom corners. Wrong shell.
    lothiandon1940 and Steve Hurst like this.
  30. Corn Fed
    Corn Fed
    Yes, you do have a 33 shell. It is not a 32 because the depth is too big and it has the funny square bump inside the lower chin pan. It is not a 34 because they had a removable bezel on top.
    You need to bend the top back into position as 31 Vicky has been explaining.
