Projects 1933/34 ford roadster project
Discussion in 'Traditional Hot Rods' started by Elvis100, Jan 13, 2018.
  1. Elvis100
    Elvis100
    Just picked up this 1933/34 Australian accessory firewall toolbox. Got it from Canada on their version of Craigslist “Kijiji”
  2. rusty valley
    rusty valley
    worthless...beer in there would be too close to the engine heat
  3. Elvis100
    Elvis100
    Making a set of A-pillar/cowl “feet” for a fellow H.A.M.B’er in Sweden
    Getting all the angles right! I’ll be able to index the A-pillar wood attachment before I bend it...should be a drop fit for original
  4. Thanks for posting all the little pieces too. Makes me think I'll be able to repair mine, "baby steps" you know.
    Stogy, loudbang and Elvis100 like this.
  5. What an amazing build. Please keep up the great updates. I really like all the homemade dies you are creating.
  6. Elvis100
    Elvis100
    Finally got the panel below the decklid. The triangular gussets are going to need some love to get the bottom to fit to the floor. I had to do some work on the set I used on my three window with an original floor. I’ll probably just make some new ones.
  7. Love watching your build progress! Thanks for sharing it.
    Stogy and loudbang like this.
  8. Elvis100
    Elvis100
    Thanks...it’s going pretty slow. I’ve been doing a bunch of side projects to pay for it, but I have set a goal to have this one on the road in 2021
    Stogy, brEad and loudbang like this.
  9. Elvis100
    Elvis100
    More work on the A-puller/cowl feet. Should be able to finish these up tomorrow
    Stogy, RodStRace, Ottomotive and 5 others like this.
  10. Elvis100
    Elvis100
  11. Gregm1
    Gregm1
    I’ll say!
    Stogy, Elvis100 and loudbang like this.
  12. vadstena bil
    vadstena bil
    from sweden
    Awesome work and they are 100 % better then aftermarket
    Stogy, brEad, Elvis100 and 1 other person like this.
  13. brady1929
    brady1929
  14. Elvis100
    Elvis100
    Thanks, if you need any parts let me know. I can make all the roadster spacific brackets
  15. Elvis100
    Elvis100
    No progress on the 34 since the holidays. I have been working on another small batch of top irons for sale and the a-pillar cowl feet for the 33 and another friends car.
  16. Elvis100
    Elvis100
    One more side project and I should be back on the roadster. I have been picking up a few parts through trading recently. Got this great set of elusive Bob Drake running boards.
    kidcampbell71, Stogy, brEad and 5 others like this.
  17. Nicholas Figge
    Nicholas Figge
    Great work
  18. Elvis100
    Elvis100
    Thanks
  19. Elvis100
    Elvis100
    Starting out slow...several of these captive nuts were almost gone and a couple had been removed and hex nuts welded in place. I was able to get period correct nut keepers from a Jeep parts distributor. These are also correct for the rear fender mountings.
    Stogy, brEad, loudbang and 3 others like this.
  20. alchemy
    alchemy
    Sometimes I also go nuts on the shape of particular hardware like that. You found a PERFECT match. Not sure I'd go so crazy on a hidden part like those plates, but I commend your efforts. Drake's and other supplier's hardware are not a good match.
  21. RodStRace
    RodStRace
    Elvis100 could you provide a part number and distributor for those?
    I'd guess they would be useful for many people here.
  22. Elvis100
    Elvis100
    Cyclone Kevin, Stogy, brEad and 4 others like this.
  23. Elvis100
    Elvis100
  24. Elvis100
    Elvis100
    This seems to be a common “alteration “. I’ll install the d-nuts tomorrow and still need to repair the mounting holes
    Squablow, brEad, Stogy and 6 others like this.
  25. Elvis100
    Elvis100
    Cyclone Kevin, hfh, Squablow and 3 others like this.
  26. Elvis100
    Elvis100
    I didn’t like the way the reproduction panel was sitting. It may just be the way the floor sits, but I did have the same problem with my coupe. Started making new panels, maybe I can use the reproduction ones on my next build.
    My press brake is working at its limit. Used an anvil and hammer to tighten up the corners.
  27. Elvis100
    Elvis100
  28. Elvis100
    Elvis100
    Bolted to the rear panel and clicoed to the floor. Dry fit the trunk panels. I’ll have to do some body work, and I might remake both of these panels
  29. FlatJan
    FlatJan
    incredible job!
  30. ol48
    ol48
    I like the details not for inexperienced
