Projects 1933/34 ford roadster project
Discussion in 'Traditional Hot Rods' started by Elvis100, Jan 13, 2018.
  1. Elvis100
    Elvis100
  2. brady1929
    brady1929
    Very nice.
    loudbang, Elvis100 and Stogy like this.
  3. Elvis100
    Elvis100
    loudbang and Stogy like this.
  4. Stogy
    Stogy
    :rolleyes:...Yes sometimes 'likes' are so not enough...but rest assured your workmanship is jaw dropping @Elvis100...;)
    brEad, loudbang, Elvis100 and 4 others like this.
  5. Elvis100
    Elvis100
    Thanks, I’ve set a goal to have it running in 2021...hopefully by the summer.
    Stogy, IowaMercMan and loudbang like this.
  6. Mat Thrasher
    Mat Thrasher
    Amazing work! I love watching this one come together.
  7. Elvis100
    Elvis100
    Just picked up the b-pillar brackets from the welder. I got these with the standard dash a while back. They had been torch cut at some point in their life to channel a car. I made the missing lower supports and had them professionally welded. I’ll clean up the welds later
  8. Elvis100
    Elvis100
    I figured I would install this shield before I connect the front and center floor panels. Of course I had to make it first
  9. Squablow
    Squablow
    Very clean work as always.
    Stogy, loudbang and Elvis100 like this.
  10. Nice replacement part!
  11. Elvis100
    Elvis100
    Joined the front and center sections...should be working on subrails tomorrow
  12. Elvis100
    Elvis100
    Finished up connecting the rear section. Installed rivets with the waffle rivet set.
    Had to press three rebates in the subrails to match up with the floor.
  13. Elvis100
    Elvis100
    Got the front subrails located and bolted in.
    Offered up the b-pillars
  14. Man you are a craftsman. just incredible workmanship.
    Some of the best I've ever seen.
    Stogy, j hansen, patterg2003 and 3 others like this.
  15. Elvis100
    Elvis100
    Thanks
    Stogy, HemiDeuce and loudbang like this.
  16. Elvis100
    Elvis100
    At the joint between the forward and middle subrail pieces there was half of a rebate missing on the forward piece. I pressed it in and joined all 3 together.
  17. Elvis100
    Elvis100
    Got the subrails all welded and attached to the floor. I’m stressing about everything lining up. For example a b-pillar being off by 1/8 inch at the base is magnified at the top. I’m going to start offering up the quarters and doors. Already have identified 1/2 inch discrepancies at the left a-pillar. I have a couple options...
    Stogy and loudbang like this.
  18. Elvis100
    Elvis100
    Welded the subrails to the floor using a plug weld every 2 inches
  19. Elvis100
    Elvis100
    Got the floor finished and primered the bottom with red oxide. One coat of seam sealer
  20. 32SEDAN
    32SEDAN
    Red Oxide colored 2k epoxy primer or?
  21. Elvis100
    Elvis100
  22. Elvis100
    Elvis100
    The rear quarter panels I’m going to use had some serious “customization “ done. The lip around behind the seat was cut off, with the top of the “hoop”. Sheetmetal was screwed welded and lead was then liberally applied to smooth everything.
    To disassemble the rear clip I had to cut in the middle of the upper body line on all three panels. I did get a SAR quarter off-cut for the driver side, but had to make the passenger
  23. Elvis100
    Elvis100
    Got the b-pillars mounted, the drivers side gaps real good. I have to take off about 1/8 inch of wood on the passenger side, but I’ll wait until I fit a few more things.
  24. Elvis100
    Elvis100
    I was able to reuse the upper b-pillar brackets, but the “hoop” that ties them together was too damaged to reuse. It has a lot of compound curves, I formed it with a buck, shrinker/stretcher and hand forming. Still needs some smoothing
  25. Elvis100
    Elvis100
    I’ve been working on the transmission. I ended up replacing all the gears with NOS I got off eBay.
  26. Elvis100
    Elvis100
    Also making cowl feet for the 33 and a fellow H.A.M.B. er in Sweden.
  27. Elvis100
    Elvis100
  28. Elvis100
    Elvis100
  29. Wow! Looks like an OEM part.
  30. Everything is looking great!
    Stogy, Elvis100 and loudbang like this.
