Technical 1933-34 Ford Inner Fenders & Fenders (Pictures Please)
Discussion in 'Traditional Hot Rods' started by 421-6Speed, Oct 3, 2019.
  1. 421-6Speed
    421-6Speed
    Looking for the differences between 33 & 34 Ford inner fenders and fenders if there is any? Pictures would be helpful if possible.
    Thanks Dan
  2. Angry Frenchman
    Angry Frenchman
  3. alchemy
    alchemy
    33 fenders had a bigger hump over the tire. Barely noticeable.
    One of the year's had a round bolt hole boss on the mounting edge near the grille that was turned slightly cockeyed. It's there on the fender and matching on the inner panel. I think it's where a brace bolts up. Can't remember which year had it.
    I think the other year had a through hole slightly below that location and the brace from the fender brace went through and down to the crossmember.
  4. $um Fun
    $um Fun
    from Nor Cal
    33 had a half bulge and the 34 full bulge, and depending on the frame number on the 33 the bolt hole boss was different as there was at least three different versions in 33.
  5. Angry Frenchman
    Angry Frenchman
    So at less 4 different type's over all. But 34 only had the long blister. Ty
    Sent from my LM-X410.FGN using The H.A.M.B. mobile app
  6. BJR
    BJR
    Pictures of the different versions would really help this discussion if anyone has them.
  7. $um Fun
    $um Fun
    from Nor Cal
    From the Early V8 club 33-34 book:
    "Front Fender Aprons -- Front fenders differed from 1933 to 1934. Generally the 1/2 bulge is 1933 and the full bulged area is 1937 with the oblong hole. Little is noticed on these so only a general statement can be made regarding timing. The 1933 lacked the cut out for the outside shock and the earliest on had one round hole for the fender support brace. These inner fenders 40-16802 and 40-16083. As many as six different styles have been identified. All fit both years and were black in 1933 and body color in 1934 unless black fenders were used."
    These are like 33 and 34 radiators, they look the same but two different animals.
