Technical 1933-34 Ford Firewall Setback Pictures
Discussion in 'Traditional Hot Rods' started by 421-6Speed, Mar 23, 2020.
  1. 421-6Speed
    421-6Speed
    I have a 33 Coupe I need to set the firewall back about 2". I would like to make it look as close to Genie as possible. I have a couple of ideas but thought I would ask other members here what they have done. Any help would be appreciated.
    Thanks Dan
    31hotrodguy likes this.
  2. adam401
    adam401
    I used a 36 ford truck firewall. Its a little reshaped at the horizontal bends. I also recessed the center even more but my engine is set back and it's an 8ba with the 8rt front stuff so its a long set-up with mechanical fan. Not the neatest work on my car but it certainly could be done neatly. I'll try to find a closer picture
    wheeldog57, akoutlaw and 31hotrodguy like this.
  3. adam401
    adam401
  4. 421-6Speed
    421-6Speed
    That looks great.
  5. 31aford
    31aford
    from az
    Here is mine setback 2 3/4". IMG_20170226_164922196.jpg
    adam401 likes this.
  6. general gow
    general gow
    MODERATOR
    i got your pm. i'll take some pics and update tomorrow with an explanation of what i did. very similar to adam's car though. stock down to the first bend, and 35 truck from there down.
    adam401 likes this.
  7. Pete
    Pete
  8. Johnny99
    Johnny99
    My buddy Mike's 3 window. Made the factory indentation 3/4" deeper. The ridge the floorboard tucks into is stock, cant see it in the photo but it runs straight across right about at the base of the distributor. And to the naysayers, yes he can get distributor out without yarding the motor forward.
  9. 421-6Speed
    421-6Speed
    Great pics keep em coming...
  10. flamedabone
    flamedabone
    This is about 4.
    This one is 3.
    The only SB Chevvie I have ever owned.
    -Abone.
    40ragtopdown and adam401 like this.
  11. My firewall that we moved back 2.5 inches and reprofiled the cowl sides
    im running a hamonic balancer on my new stroker engine and a McCulloch supercharger so needed some room up front of the 8ba. Screenshot_20200324-221303_Instagram.jpeg
    Sent from my SM-G930F using The H.A.M.B. mobile app
  12. sloppy jalopies
    sloppy jalopies
    '37-'39 trucks had the shallower offset in the firewalls... but had a battery box factory...
    wheeldog57 likes this.
  13. Johnny99
    Johnny99
    Another one looks to be nicely done.
    40ragtopdown likes this.
  14. 34Larry
    34Larry
    100_1559.jpg firewall 1.JPG My solution for getting my 331 shoehorned in. firewall 1.JPG
    1morecarIpromise! and ss34coupe like this.
  15. Johnboy34
    Johnboy34
    from Seattle,Wa
    I didn't worry about losing a little extra in a sedan. 4 inches. 20140918_084940.jpeg
    Sent from my SM-G973U using The H.A.M.B. mobile app
  16. 421-6Speed
    421-6Speed
    Lots of great input here guys thanks. Here is what I started with. The PO did this I cut it out and patched it with a original piece. Figured I would patch first before removing the firewall and setting it back. I'm running a Cadillac 390 so I can't just notch the back for the distributor. I think I can get away with 2-1/2" I have a 40 firewall I am going to use the angled section of and then the upright on my original. I really like how Monster Kid & Hotrod Grille did theirs. Here are a few pics.
    20200321_172357.jpg 20200325_185832.jpg 20200321_172317.jpg 20200321_172346.jpg 20200321_172335.jpg
  17. 421-6Speed
    421-6Speed
    Here's what I came up with.
  18. Besty34
    Besty34
    [​IMG][​IMG][​IMG]
    Moved mine 2” to clear Hemi
    earlymopar likes this.
  19. 421-6Speed
    421-6Speed
    Finished up the majority, just need to work on the toe board and weld up the holes.
    Pass The Torch, X38, duncan and 4 others like this.
  20. Eldonius
    Eldonius
    from Louisiana
    Love what you did with the canister in the firewall!
    Besty34 likes this.
  21. hemihotrod66
    hemihotrod66
    Engine was set back 11 inches to clear blower drive....Removed all the factory firewall and moved everything back 11 inches in my sedan....Also wanted to be able to remove the valve covers to adjust the valves being a solid roller lifter cam... 392 Hemi 4.jpg
    Eldonius likes this.
  22. Eldonius
    Eldonius
    from Louisiana
    Did an 11” setback really cramp the floorspace on the inside? I also have a sedan, so curious about this. Seems with a sedan it wouldn’t be an issue because you could just set the seats further back. Your setback came out looking really clean by pulling the entire firewall back, and not just notching it like most builds. Nice work!
  23. Pitbullgoingpostal
    Pitbullgoingpostal
  24. Dago 88
    Dago 88
    Went 8" to make the Rocket a little more comfortable :) 61923902_404082653510906_6216448021127757824_n.jpg 12966540_10207011174291738_677921576_n.jpg
    triumph 1 likes this.
  25. dumprat
    dumprat
    from b.c.
    With such large set backs don't you run out of leg room in a hurry? Or is everyone 5'4"?
    I realize you can move the seat back but the toe board angle must be gone.
  26. sloppy jalopies
    sloppy jalopies
    5'6" on a cold day...
    1morecarIpromise! likes this.
  27. That lets us out Matt.
