SOLD 1933/1934 Ford frame. It’s rough but salvageable. Will need front frame horn repaired on drivers side, and rear horns have been bobbed with a torch. There is a slight kink in the front passenger rail, but a little heat and a hammer will fix it.Some genius “drilled” a hole with a torch right through the chassis number, so it will be pretty hard to title it with the original number. Like I said, it needs work, but it’s worth saving IMHO. Located in Spring Hill, Fl. 34606. $500 OBO. .
