Technical 1932 sedan rear window garnish
Discussion in 'The Hokey Ass Message Board' started by ROBERT JAM, Jan 3, 2020.
  1. ROBERT JAM
    ROBERT JAM
    Will a 1932 sedan rear garnish fit any other1932 models
  2. I don't think so unless it is another 32. HRP
  3. alchemy
    alchemy
    They are the same shape as a 5-window but a different thickness. I forget which is thicker but someone will know. The difference is minor.
  4. Sure, but probably not unless you fettle the garnish or the car.
  5. The rear garnish moulding is noticeably thicker for the 5 window coupe. There is also a difference from early to late sedan rear mouldings, it is in the number of mounting screws.
    5window likes this.
  6. Fordors
    Fordors
    The depth of the sedan garnish is thinner, I imagine to afford a bit more headroom.
    The coupe measures 1 3/8” and the sedan is only 3/4”.
    deuceman32 likes this.
  7. ROBERT JAM
    ROBERT JAM
  8. 42merc
    42merc
    The deeper garnish on the coupe accommodates the wood surround that facilitates the roll down window.
  9. ROBERT JAM
    ROBERT JAM
  10. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    The sedan rear window garnish will also fit he 4 door and vicky.
