I have three panel that I got with my 32 5window One is a trip tray that I haven't figured out where it goes and then there is a panel that matches the rear profile of the car but does not work with the rear panel and inner from of the 5w so I believe it's a 3w and the last panel with holes I believe is the inner panel from a 3w. If someone could clarify this it would be appreciated. Thanks rich
Yeah that's what I was figuring but I can't seem to figure out how it mounts does any one have a picture of one mounted in place?
The other two are from a 3 window. The drain fits to the wood for the rear window Singlefingerspeedshop.com. Detroit
1. Drain panel that mounts under back window. Attaches to wood under window 2. Not sure ..either a header panel or package tray panel behind seat 3. Panel below decklid on the inside. The ends of these are usually hogged out where the back of tail lights once were
The middle panel fits the radius of rear of the car and the ends lay into the sub rail extension pieces in the body so I would say it appears to be a 3w rear panel? It's pretty heave gauge too.
Check this thread for the drip tray; yours appears to be for a not roll down window. http://www.jalopyjournal.com/forum/showthread.php?t=638787
