Projects 1932 Jalopy Roadster Build
Discussion in 'Traditional Hot Rods' started by deluxester, Jul 20, 2019.
  1. deluxester
    deluxester
    I know I’m jumping around quite a bit. Started on a budget tonneau cover this morning made from some remnant painters tarps I found in my tool shed. CAEBFF7B-5693-476E-BE74-B87B2057E6DF.jpeg AB779EB5-6189-493C-9A57-01C4826B0472.jpeg A4421C01-9095-4380-8DB4-A4E018E54ACC.jpeg
  2. nunattax
    nunattax
    jumping around can be good,keeps the job interesting and you can be working on 2 or more jobs at a time improving things as you go
    deluxester and HellsHotRods like this.
  3. jimmysweden
    jimmysweden
    from sweden
    Yes. It's like that..I also learning when i posting. Feedback is a part of this forums. it's not only pisctures.
    deluxester likes this.
  4. 421-6Speed
    421-6Speed
    Thanks for the compliment.
    The cut out on top of the generator see the one in the pic of my 36.
  5. redzula
    redzula
    I took notes on the e brake tube situation if anyone needs them in the future. It'll probably be in the test.
    Awesome build so far
    Sent from my rotary phone using The H.A.M.B. mobile app
    brEad and deluxester like this.
  6. the oil soup
    the oil soup
    from Tucson,AZ
  7. deluxester
    deluxester
    Chopp'd49 likes this.
  8. deluxester
    deluxester
    E-brake handle bracket.
    Shadow Creek, dlw1932, brEad and 4 others like this.
  9. Drmalacarne
    Drmalacarne
    Great craftsmanship!
    Enviado do meu iPhone usando H.A.M.B.
  10. deluxester
    deluxester
    Thanks!
  11. joshuajardine
    joshuajardine
    from NSW OZ
    Love this build!
  12. deluxester
    deluxester
    Found an odd piece of steel channel in my garage so I tried to use it for the master cylinder bracket.
    continentaljohn likes this.
  13. deluxester
    deluxester
  14. deluxester
    deluxester
    Some progress on that cover also.
  15. continentaljohn
    continentaljohn
    Love the tonneau cover and your approach to the whole car. It’s awesome to see the Lincoln steering wheel in a great home...
  16. Mart
    Mart
    Good idea to use the channel. Built in strengtheners.
  17. deluxester
    deluxester
    Connected the emergency brake using all thread and some jamming nuts.
    brEad likes this.
  18. deluxester
    deluxester
    Mock up. Going to retrofit these old seat springs I bought from a friend last year. Not sure what car they were pulled from, but they look close enough to work with.
    dlw1932 likes this.
  19. alchemy
    alchemy
    Double check your emergency brake handle will have enough pull distance to engage the brake. Mine didn't. I made a bellcrank that magnified the pull. Basically an arm pivoting off the right side of the frame, the handle's rod connecting towards the middle, and the brake cable connecting on the end under the torquetube. I don't think I doubled the pull distance, but maybe a third or half more.
  20. Deuce Daddy Don
    Deuce Daddy Don
    Did you know that's a '32 Model B hood??
  21. alchemy
    alchemy
    Just a regular 32 hood Don. Not an early, not a late 25 louver.
  22. deluxester
    deluxester
    I had no idea.. how can you tell?
  23. Deuce Daddy Don
    Deuce Daddy Don
    Easy-----Shorter louvers & not as many. Due to over heating, Henry had more louvers made in the following models plus more stamped in. That seemed to correct the problem. Also a Model B light bar had a solid stainless wrap from light to light---No hole for the V8 emblem.---Don
    chryslerfan55 and deluxester like this.
  24. Deuce Daddy Don
    Deuce Daddy Don
    You can read my reply.
  25. alchemy
    alchemy
    That's all good, but that doesn't make it a "B" hood. It just means it was made before October 1932. All the V8's had this same hood as well up until October.
    A headlight bar can be distinguished as for a B or a V8, but the 20 louver hoods can't.
  26. deluxester
    deluxester
    This was my understanding.
  27. 54reno
    54reno
    Nice build, great job.
  28. deluxester
    deluxester
    18D7B280-12D0-49B5-8B27-06AA60230006.jpeg I thought I found and patched all the pinholes but it looks like I still had a leak on this corner. Jacked the car on one side to shift the gasoline inside far enough for me to perform more JB Weld emergency surgery last night.
  29. Drmalacarne
    Drmalacarne
    Old fuel tanks are a plentiful source of headache!
    deluxester and kidcampbell71 like this.
  30. deluxester
    deluxester
    A fresh new tank is on the wish list for sure!
