Projects 1932 Jalopy Roadster Build
Discussion in 'Traditional Hot Rods' started by deluxester, Jul 20, 2019.
  1. deluxester
    deluxester
    After completing my Model A roadster project last year, I was certain that I would be keeping it for a very long time. I imagined myself driving it as an old man, reminiscing on how I had built the car when I was much younger and more ambitious. I assumed I would someday be teaching my daughter how to drive its manual transmission, and how to keep it running. And maybe she’ll want to keep it long after I’m gone.
    But after finding this 32 roadster, I decided I’ll do all of those things in this car instead!
    This roadster was pulled out of storage last year after sitting disassembled since the 60’s. I wish I had more back story on it, but I honestly can’t complain as the car was relatively complete and dry with some minor patches that were nicely done.
    I’d like to build the car into a prewar style hot rod while preserving as much of its aged appeal as possible.
    46D49600-1D5F-4FC1-B0F4-B832F2DA1A30.jpeg 13035B05-9EB5-4805-902F-D26B12B2376B.jpeg 13A334EC-21E9-45D6-A7E3-F38A72D085E3.jpeg
    Torkwrench, Tim, 48fordnut and 29 others like this.
  2. deluxester
    deluxester
    I already started disassembling the roadster. Fenders now off, @HellsHotRods helped mount up some 750x18’s at the rear. The original motor was pulled.
    Tim, 303racer, exterminator and 17 others like this.
  3. deluxester
    deluxester
    My daughter helped remove the horn button, steering column and box.
    Tim, 39WILLZ, Blade58 and 29 others like this.
  4. Stogy
    Stogy
    In the Weeds Awesome...Life's like that...Look forward to what you have on your mind...and congrats...;)
    deluxester likes this.
  5. Kiwi 4d
    Kiwi 4d
    You lucky son of a gun, this is what most Rodders dreams are made of.
    I hope you will keep the fenders on.
    I think calling it a jalopy may be a little harsh. We are your visions for the finished look??
    weps, Stogy, deluxester and 1 other person like this.
  6. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Great job Steven, perpetuating history and hot rods!!!! Really looking forward to this adventure and seeing how it evolves...
    robber grin, Stogy and deluxester like this.
  7. ... sooooo' clean. Dig it ! Big hearts for the kiddo' helpin'. My 7 year old would like the moving pad comfort, for her little legs too. So stoked for you ! ... and of course, for her. Very cool. She has a `32 ! :D
  8. Lucky Guy! 32 original Ford roadster and the best helper possible. :cool:
    greaser, Stogy and deluxester like this.
  9. pumpman
    pumpman
    What's to say but MAN!!!! Good luck to you and your little helper.
  10. deluxester
    deluxester
    The fenders are definitely going back on eventually. I’d like to get the front end a bit lower, and have the option of pulling them off for races.
    glorydime, Stogy, slv63 and 3 others like this.
  11. craig b blue, Stogy and deluxester like this.
  12. deluxester
    deluxester
    Disassembled the stock 32 steering box...
    0A1FFA4D-0FB6-4AE4-8357-C2DE8EBC7584.jpeg 8E6CE6FA-619F-49B2-B928-C45C098ED3BA.jpeg
    Tim, dwollam, Nailhead A-V8 and 3 others like this.
  13. deluxester
    deluxester
    The worm screw/cam looked pretty nice, so I only had to replace the worn races, old bearings, and damaged seals. The box was cleaned and painted.
    4CA4D4B0-C225-42D5-AB1D-133D77E5755C.jpeg B9751AF2-2903-49EE-BCB1-E006C88A43AF.jpeg 5CF1EDCD-85C2-4607-941E-E2ECB7D38475.jpeg 46A4605C-670E-49B9-8CCB-B47EC329C2D2.jpeg
    Tim, Rathbone, Runnin shine and 8 others like this.
  14. Daaaaang!
    How do you guys find these treasures???
    Jealous, to say the least.
  15. deluxester
    deluxester
    Reassembled and adjusted by first setting the end play of the worm screw/cam by shimming the upper cap where the column exits the box.
    Next, I adjusted the eccentric nut at the side for gear lash between the worm screw and sector shaft gear when the steering wheel or pitman is set to center.
    And finally, I set the end play of the sector shaft by the screw and locking nut at the opposite side of where the sector shaft exits the box.
    Now,, I learned this sequence from information shared here on the HAMB. Please let me know if there is a better way to make these adjustments. The assembly feels smooth with almost no excess movement, but I might discover that more adjustments are necessary once I’ve re-installed the assembly onto the car.
    Tim, 48fordnut, dwollam and 14 others like this.
  16. x77matt
    x77matt
    Oooh! Watching this or for sure. Looks like a great find!
  17. brady1929
    brady1929
    Cool roadster.
  18. scotti32
    scotti32
    Wow, awesome find
  19. deluxester
    deluxester
    The original axle was not as straight as I was hoping. Some gentle torching and pressing helped correct the camber which was originally +3/+2 degrees at the wheels. I was told that Ford initially set their 32 passenger front ends to +1 degree (-6 at the kingpin and +7 at the spindle) for road crown, but I ultimately set mine closer to 0 on each side.
    6723AF0A-5863-4A31-A306-7DDDCEF6F7E6.jpeg D113CE52-9515-4A5D-85DA-CC1E315AC6B1.jpeg 54B4A4CB-1140-45ED-97B9-753B75D9D310.jpeg 287E170C-F1DF-4B9A-B602-7DC9A19835B8.jpeg
  20. deluxester
    deluxester
    Yes but I might reassign her to heavy line and motor works. She insists on painting the car purple, pink and orange, with other “rainbow colors”
    chryslerfan55, dwollam and Stogy like this.
  21. deluxester
    deluxester
    I worked on the front spring this morning. I’m going to use a reversed main leaf to help lower the front on a stock axle. New bushings pressed in and each leaf cleaned for paint.
    Tim, Runnin shine, waxhead and 2 others like this.
  22. Rickybop
    Rickybop
    from Michigan
  23. deluxester
    deluxester
    With the front end back together kinda, time to start on rear.
  24. deluxester
    deluxester
    I am very pleased with my recent swap meet find - snap on leaf spring tool works awesome.
  25. deluxester
    deluxester
    Thank you sir
  26. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Looking good and making progress Steve!!!!
  27. deluxester
    deluxester
    Original backing plates and mechanical brake hardware removed this morning. I started cleaning the bearing and axle surfaces.
  28. deluxester
    deluxester
    1369A174-C354-4B03-876C-FF05CACFE49E.jpeg Alright... not going to win any car shows but the differential is clean and painted. The plan is to eventually build out a 36’ Columbia. I’ll make that one pretty.
  29. deluxester
    deluxester
    Freshened up some rear backing plates as well.
  30. Congratulations, your a lucky guy. HRP
