1932 Frame question
Discussion in 'The Hokey Ass Message Board' started by 08racer, Feb 28, 2013.
  1. 08racer
    08racer
    from Gilbert AZ
    Do you guys think this thing is c-notched or Z-ed in the rear to get that low?
    The reason I ask is because it still has the gas tank out back. Im not so sure you can get it down that much with a c-notch. I could be wrong though. It happened once before.
  2. olskool34
    olskool34
    Really hard to tell from the pics but I would say it is z'd.
  3. I think your right, it would have to be one hell of a notch, that frame is sitting pretty low.
  4. 08racer
    08racer
    from Gilbert AZ
    Seems like a lot of work to keep the gas tank.
  5. Deuce Daddy Don
    Deuce Daddy Don
  6. If its Z'ed, how did he keep the tank in the stock location? Shorten the boot lid and other panels?
  7. Z up and a Z back down - effectively a big ass c notch that's deeper than the frame.
  8. olskool34
    olskool34
    Yeah I agree with that.
  9. That would raise the tank in respect to the lower edge of the door.
  10. Nope
  11. R35J1S
    R35J1S
    from Missouri
    looks like a c notch with the frame sitting on the rear axle tub or damn close to it and a really tall set of rear tires that makes it look even lower
  12. So a C notch then. Not a Z. Coz two Z's make a C.
  13. hallrods
    hallrods
    I think it's C notched
  14. Its up there in my post.
    In no way could it be called a C notch because its not a notch by any definition I know of. It has to break thru the top of the frame.
    Probably more like a mini truck frame treatment.
    Or maybe its under slung set up
  15. metal man
    metal man
    I think what 31 vicky was saying must be the case. It's not just a c-notch,but a section of the frame is raised up above the axle. The rear of the frame seems to be in the original position in relation to the body.
    A c-notch is just a notch in the rail, with the top of the rail keeping it's original shape.
  16. If thats ride height....It's TOO low in the rear.
  17. Gettin low gettin low from the window , to the wall! Till the sweat drops off balls ! Till all these bitches crawl. Y'all skeet skeet skeet mother fuckers .
    Every time I see a low low car I think of them goofy bug eyed crack heads singing that song
  18. HAHAHA you said mini truckin!
    A C notch no matter the magnitude of it should have whatever is taken from the bottom of the rail added to the top. Thats why i used the term C notch.
  19. Look at a mini truck treatment
    If that's not two Zs facing each other then nothing is .
  20. Not if he did them in an arc :)
  21. daddio211
    daddio211
    I don't think the owner is a HAMBer, but his car has been discussed on the Utah board to some degree. I'll post a link there, maybe someone can answer the questions exactly. One of us Utah guys knew a LOT about the build.
  22. 08racer
    08racer
    from Gilbert AZ
    Thanks daddio!
    If you have any more pics please share.
  23. 08racer
    08racer
    from Gilbert AZ
  24. [​IMG]
    I'd vote for a Zeeee
    Mine has a 6in zee in the back and a 6inch bell in the front.
  25. fab32
    fab32
    I vote deep C-notch and very little axle clearance at ride height. YOU would be surprised with how small a frame section you can get away with over the axle but adding some materiel above to restore lost strength is always a good idea. We add a cresent shaped piece on top of the frame and modify the floor so it rises over the hump in the frame.
    Frank
  26. 08racer
    08racer
    from Gilbert AZ
    Seems thats they way they build them in Utah. Here is another car that looks really similar to the green one. It says its c-notched in the ebay ad.
