Hot Rods 1932 Ford torque tube and drive shaft lengths
Discussion in 'The Hokey Ass Message Board' started by seabeecmc, May 11, 2020.
  1. seabeecmc
    seabeecmc
    What I need are dimensions (length) of a stock '32 FORD model 18 (V8) torque tube and drive shaft. Appreciate the help, Ron
  2. Pete Eastwood
    Pete Eastwood
    from california
    I'm not sure what your end goal is , but if you are shortening a torque tube on a later rear end , to put it in a 32 , you will need a different dimension .
    The later banjo's are bigger .
    You will need the dimension from the center line of the rear axle to the front of the torque tube.
    The later torque tube will end up being shorter than the 32 torque tube because of the banjo diameter difference.
    Hope this makes sense .
  3. seabeecmc
    seabeecmc
    Thanks Pete, my only end goal is to learn the length of the original '32 FORD V8 torque tube and the length of the original V8 drive shaft. Appreciate your input, Ron
  4. hightower611
    hightower611
  5. bushwacker 57
    bushwacker 57
    Drive Shaft late 32 51.660 Torque Tube Late 32 53.665 from Ford factory drawings. 2010 Ford Barn.
