32 Ford Roadster Tech Sheet SOLD----SOLD----SOLD Engine/Driveline Center Bolt Small Block Chevy built by John Barrett (335 HP) http://www.jonbarrett.com/330.html Performer Polished Intake Manifold Edelbrock 650 cfm Performer Carb Chrome Water Pump Chrome 100 amp 1-wire Alternator Polished Billet Wire Loom p Chrome Valve Covers Polished finned Air Cleaner High Volume Fuel Pump (Mechanical) Custom Alternator Bracket Billet Aluminum Billet Pulley’s Electric Fan (thermostat) controlled Aluminum PCR Radiator Black TAYLOR 8MM Spark Plug Wires polished spark plug wire looms 700R4 Trans with LOKAR Shifter and Cables and more... Trans Cooler (With its own fan) HEI distributor Factory GM Gear Drive Starter Exhaust Block hugger HEADERS (thermal-coated) by Sanderson Aluminized steel Pipe from headers to Turbo mufflers Aluminized pipe from mufflers to stainless steel tips Note – Exhaust is over the axle installation… Not the cheap way under the rear… This exhaust is nice and tight no rattles… Suspension FRAME: “Just a Hobby” Fully Boxed Frame Black Powder Coated NOTE: Just a Hobby was bought out by LOKAR they now supply this chassis8 point tubular Cross member with trans drop out C-Notched Rear Chrome Aladdin Coil over shock with tri 4-bar Rear 8" Ford Rear Smoothed and Powder coated Super Bell 4" Dropped Hair Pin Wishbones (Black powder coated) Super Bell spindles with Super Bell disc brakes Super Bell steering arms Steering Damper Brake Power Booster (Under Floor) Rear Brakes are stock 8 inch ford. Pete & Jakes Front Spring Flaming River Steering Box Borgeson joints and shaft Chrome Steering Column Repo (Bob Drake) 1940 ford steering wheel Your choice for Wheels and Tires….. I have Smoothies with Trim rings and 42 Ford Polished caps… I also have wire wheels….. Both sets of wheels have NEW TIRES on each set. Ford Wheels Bolt Pattern 5 on 4.75 front and rear Body Harwood 32 Ford Hi-Boy Roadster Body (Note-This is the Cadillac of fiberglass bodies – Harwood has stopped manufacturing these and they are getting harder and harder to find – These bodies are stamp steel reinforced and have great door and deck lid alignment. They also used Kevlar in their body construction. 2 Inch extended doors and drivers compartment. Body has been blocked out and is near ready for primer… Trunk Lid with Gas Cylinders (Not Rumble Seat) Chrome & Stainless Windshield Frame 2 inch chop Stainless Front spreader with LED parking & directional lights Stainless Rear spreader bar Tail lights are 1939 Ford tear drops Billet alum License Plate Trim with Plate lamp Original style 1932 ford head lights Chromed Steel shock mounts Steel (Hagen) one piece TOP Hood Steel Hood Sides (SMOOTH – No Louvers) NEW but these need to be fitted and attachment fabricated (Currently Raw Steel) Hood center trim (Bolted to 1 piece hood) Hood center trim custom trim that goes on the cowl Radiator shell chrome and stainless trim parts. Shaved Doors with hidden hinges. Grill Shell Is original 1932 ford with a reproduction 1932 ford Stainless Steel Grill is polished stainless steel aftermarket (Rod Style – No Crank Hole) Interior New Wise Guys seat frame (Glides front to back) Seat Reclines & folds forward…. Seat bottom tilts forward…. All of the foam for the seat upholstery is included.. Rugs (NONE) Interior Panels (NONE) Heater mount behind dash (It works Great for those chilly night rides home) Gauges VDO (6 Gauges) Billet aluminum Gauge Bezel with engine turned styling.. Gennie Shifter Reproduction Chromed Emergency Brake Floor mounted hi beam switch Custom Column Drop Chrome plated steering column Billet Aluminum remote under dash trunk release Lokar Spoon accelerator pedal with custom pad Lokar Custom Brake pedal Dash Mounted ignition switch, Dash mounted light switch, Dash mounted heater switch Dash mounted Master Power Disconnect. You can kill all the power to the car so it will not start. Trunk has been wooded for upholstery… Battery and Security Solenoid is mounted in the trunk Number 2 welding cable for all connections to Battery and Ground Wiring Based on a Ron Francis wiring panel. It’s a work of art with every terminal remotely mounted and numbered on Jones blocks… Located on interior side of the firewall.. behind hidden panel for easy upholstery Copper Buss bar grounding (copper) All the electrical wiring is NEW and wired to GM color Code. All in all there is OVER 30K invested in this build not including 1 minute of labor….. Obviously everyone has there own taste and there are things that a new owner would want to change but you must also consider that this car is complete and drive able. It is currently registered and plated in the state of NJ with a 1932 ford NJ Title. Interior….. I can provide you with contact info for a great upholster in Conn….. My estimation it would look great with A nice White & Color (Red, Blue Yellow) rolled and pleated interior would make 100% improvement to the Roadster I having an abundance of vehicles the only reason that I’m considering selling the 32 is to move on to other projects. Notes 2 inch chopped windshield frame beautiful chrome plated These can go with the car if my price is met……… My asking price is 26,000 as is where is…. This is a PROJECT..... Currently running and on the road... Needs Paint and Interior..... I have lots of photos and will gladly share.... I have problems posting photos on HAMB.... Email me and I will send pictures to you.... See Pictures below. Note.. The car will come with Brand New Smoothie wheels (Black Powder Coated) including NEW Stainless Trim Rings and 42 Ford Hub Caps.. I have additional parts that I have collected that can go with the deal at a reduced price. (Stock Height Windshield Frame) (Convertible for stock windshield) (Wind Wings) Rich King 11 North Main Street Boonton, NJ 07005 973-335-6621 otrr@yahoo.com
