Up for sale is my primary hotrod for the last 10+ years. Car was finished about 11 years ago with details finished since. Car has been driven on several 2,000+ mile drives with no issues. Car is reliable and has a solid mix of traditional and modern parts to make maintenance simple. I built the car to feel gritty and broke-in. The car cruises effortlessly at 70 mph. The Cadillac has good torque and the quickchange is geared to do 70 mph at 2,000 rpm. On my last trip to So Cal, was getting 21/22 mpg at 75 mph. The car tracks down the road straight and is fun to drive. The quickchange gear noise is barely noticable, not overwhelming. ***Car is registered and titled in my name with an Oregon 1932 Ford RD (Roadster) title 18xxxxx serial number stamped in frame. BODY -Body is Brookville, very early, built in 2002, body #317, crisp stampings. -Re-enforcements for both cowl and behind seat of tubular steel to remove cowl shake. -Lower posts, tack strip around cockpit, grillshell, insert, hood and windshield are original -Windshield chopped 3" -Car is brush painted over DP primer -1939 Ford taillights -Early license plate light -Oregon plate - if car sells outside Oregon, plate stays DRIVETRAIN -Near new Walker radiator -1956 Cadillac 365 CI motor -Edelbrock 600 cfm carb -Torq-tube headers custom built by Matt at GearDrive in Minnesota -Headers ceramic coated by RM coatings in Oregon City, OR -New clutch, pressure place and re-surfaced flywheel -Adapter from Cadillac to BW T-10 from Bendtsens, scattershield -Early Frankland QC, 9" axles and brakes/e-brake (functional) -Have both 5.5"bc & 4.5"bc axles that will go with the car, drums drilled for both CHASSIS: -ASC rails, tubular crossmembers, hairpin front, P&J ladder bars rear -Model A spring and crossmember over quickchange -Superbell 4" dropped and drilled axle -Early Ford front brakes -New kingpins -Hydraulic clutch -Dual reservoir master cylinder -Functional early Ford e-brake handle -Custom headlight bar by the one and only Chris Jory -BLC original headlights -Tanks gas tank, notched for quickchange clearance -Rear So-Cal shocks Interior: -Model a coupe seat, adjustable slides in place, adjusted currently for me, (6'7") -Material is 3" Oxblood tuck & roll from '50 Buick Convertible done decades ago -Included is more than enough material to finish door and kick panels -Brookville stock dash, (5) functioning SW gauges. -Wood toe boards, custom metal tunnel -1947 Lincoln steering wheel -1940 column on 1953 F-100 steering box Wheels/Tires: F: 1940 Ford 16" x 4.5" steel wheels, Firestone 5.00x16" ribbed track tires R: 1940 Ford 16" x 4.5" steel wheels, Firestone 7.50x16" bias ply Original 1940 Ford Deluxe hubcaps I know I have missed a lot of details, please contact me with questions. I am not on the HAMB too often, so for a quick response, Chris McCormick vintageroadster@gmail.com
