1932 Ford Roadster ~ Full fender ~ Steadfast
Discussion in 'Cars For Sale' started by Steadfast mfg, Aug 30, 2016.
  1. Steadfast mfg
    Steadfast mfg
    City: Mansfield
    State: Ohio
    Price: 55,000.00
    [​IMG][​IMG]
    Up for Sale is a Steadfast built 1932 Ford Roadster!
    I started building this car for myself and then the reality of "time management" set in and I have decided to let someone finish this one off and get back on some previous commitments.
    I have had this car in my head for awhile and I believe it's on the right track to be a serious contender for "Hot Rod of the Year"!
    The Stance and proportions have been nailed so it's going to be easy for anyone to finish this baby out and start collecting some serious attention!
    I would not have a problem finishing up some loose ends or recommending a shop close to you.
    I urge you to call me with any questions!
    Henry
    This Roadster is set on top of one of our full Steadfast, stretched (at the wheel base) chassis. With arched heavy duty cross member, custom one off motor mounts and rear frame rail modification for the perfect tank fit. This is set up for a 350/Tremec 5 speed transmission (which are NOT included / motor & trans shown for photos only)
    Here's What You Get:
    Front
    • 4in Dropped I Beam
    • Durant SL5 Spring
    • So~Cal SS King Pin Set
    • So~Cal Shackles GT2
    • So~Cal Shocks
    • Super Clean - Unpitted set of '47 Ford Wishbones w/ So~Cal Rod Ends
    • Pete & Jakes Spring Clamp Eliminator
    • Pete & Jakes Panhard
    • Pete & Jakes Tie Rod Kit
    • Pete & Jakes Drag Link
    • Pete & Jakes Adjustable Perches
    • Pete & Jakes Lower Shock Mounts
    • Pete & Jakes Steering Arms
    • Pete & Jakes Spindle
    • Pete & Jakes Spindle Nuts
    • Pete & Jakes Vega Box Mount
    • Vega Steering Box
    • Thompson Garage Lincoln Backing Plates w/ Drums
    Rear
    • Pete & Jakes Ladder Bar ~ drag race
    • Pete & Jakes Panhard Bar
    • Posies Super Slide Spring
    • So~Cal Shocks
    • So~Cal F-1 Style Shock Mounts on Rear
    • Steadfast Bracket Kit
    • Johns Industries / 9 in. Factory ~ Ford Rear
    • Johns Industries / 9 in. Factory ~ 3rd Member Posi 4.11
    • Johnson's Hot Rod Shop Sway Bar
    • Ford Racing Drum Brake Kit
    Body
    • New Brookville '32 Roadster Body
    • Brookville Flat Firewall Kit ~ modified
    • Brookville Fender Kit
    • New Rootlieb 25 Louver Hood - cut modified and fitted
    • '32 Ford Headlight Bar ~ custom bent
    • Vintique Tank
    • Custom Splash Apron ~ started
    • Brookville Grille Shell
    • Brookville Rear Splash Aprons
    Chassis Miscellaneous
    • Drive Shaft & Yoke set up for Tremec 5 speed
    • Full Stainless Steel Exhaust done w/ Speedway Headers & Flowmaster Hushpower Mufflers
    • Custom Rear Brake Hose & Mounts
    Miscellaneous
    • Pines Winter Front Grille ~ By Alumicraft
    • Headlights w/ turn signals
    • Walker Radiator
    • 39 Teardrops ~ recessed into tail pan
    • So~Cal License Plate Trim
    • Limeworks Decklid Handle
    • Limeworks '40 Ford Steering Wheel, Column & Drop
    • Limeworks Gas Pedal
    • Kugle Under Dash Brake & Clutch Assembly
    • Clean Ohio Title!
    Wheels & Tires
    • front: '40 Ford 16 x 4 Steel Wheels / 450/475-16 Firestone
    • rear: '40 Ford Style 18 x 5.5 / 700-18 Firestone
    NOTE: The Front Wheels were the nicest un-pitted steel wheels I have ever owned. Front & Rear wheels had weld seams smoothed and have been body worked and painted.
    NOTE: Motor & Transmission are NOT included ~ shown for photos only!
    You can find us on Facebook or Instagram / Steadfast Mfg
    SHIPPING.... We can deliver (limited area) for an additional fee, call us for details.
    Steadfast Manufactures Quality Traditional Hot Rod Parts Steadfast Manufacturing specializes in custom hot rod fabrication and product design. We manufacture and sell our own products that are designed and built in our own facility. None of our products are manufactured outside the USA.
    Additionally, we are authorized sellers of high-quality hot rod and performance parts from Pete and Jake's, Brookville Roadster, John's Industries 9 Inch Factory, Perfection Hot Rod Parts by Johnson's Hot Rod Shop, Vintage Air, Detroit Speed Equipment and LimeWorks, just to name a few.
    We are just a phone call away to answer any of your questions
    419.526.3132 or 419.632.3315
    * * * POSSIBLE TRADE! * * *
    We might consider partial trade for an Original Model A or 1932 Ford Body.
    Henry likes to set up his own ride's so we are not looking for any finished builds.
    Send us a picture, tell us what your thinking.
    Thanks
