Projects 1932 Ford Roadster Build- "The Template Roadster"
Discussion in 'Traditional Hot Rods' started by x77matt, Jan 4, 2018.
  1. x77matt
    x77matt
    So, here are some progress photos from the body prep... I blasted the body and then put it in epoxy (Nason ful poxy). After that, a scuff and skim coat of filler. During the blocking process, there were high spots that exposed the metal and it's really humid in Michigan right now, so I re-sealed it with epoxy after the rough in with filler was complete. After this stage, I will move to evercoat spray on polyester followed by 2k primer. I will paint it eventually with single stage urethane.
    At this point I'm pretty well finished with the beltline on down, and turning my focus to the top half.
    20190519_191606.jpg 20190519_191615.jpg 20190601_211505.jpg 20190704_122550.jpg
    ct1932ford, teach'm, brEad and 6 others like this.
  2. magnus13
    magnus13
    Such a cool print. What's the size of that quarter panel one?
    Sent from my SAMSUNG-SM-G891A using The H.A.M.B. mobile app
  3. x77matt
    x77matt
    More progress- spent the last couple days on the quarter uppers and trunk bead area. Skim coat, block, and re-seal.
    20190705_224640.jpg 20190705_231109.jpg 20190702_142724.jpg 20190705_174002.jpg 20190706_122720.jpg
  4. Deuce Daddy Don
    Deuce Daddy Don
    No, just the print you are displaying on your wall.---3 views.
  5. Deuce Daddy Don
    Deuce Daddy Don
    3 views-----36X89 inches.
    sko_ford likes this.
  6. pivir123
    pivir123
    Great Build! I enjoy following along.:):)
    x77matt and loudbang like this.
  7. Your car is looking great! Body work is such a tedious stage of the project.
  8. x77matt
    x77matt
    Thanks! Very tedious! Every time I think i got it perfect, oops, another spot! The big thing now I learned is I can get the gaps adjusted perfectly then just breath on the frame and it moves them around. I'm going to pull the body before I go any further and finish welding and riveting the frame to make the foundation more solid. I'd hate to get it in color and find out the hard way I should have done something different
    Atwater Mike, Malcolm, brEad and 4 others like this.
  9. The other day, I was sitting here on the H.A.M.B. kind of bummed. There just doesn't seem to be a lot of build threads going on these days. Lots of "what did you do today" and "imagine if" fluff. Then I came across this. Awesome thread! Love seeing the progress. Will be following along.
  10. x77matt
    x77matt
    Whew! Its been over a month and a half and I finally got a chance to get out in the garage today! Work trips, family vacation, and kids activities really eat the weekends (but worth it!)...
    I've been stressing about the rear decklid fit, since I am so far along with the body work, I was afraid I'd have to undo a bunch of stuff to get it fitting right. Well after much thought, I carefully removed some floor rivets, and cut loose the lower rear panel. I was able to push the rear of the quarters around enough to get the gaps nice, reweld the rear cross panel and re-rivet the floor back together. The only casualty was the rear panel that I had to add a 1/4" to in order to gap everything nicely.
    Hopefully tomorrow I will pull the body off so I can do the final last details on the chassis.
    20190901_191007.jpg 20190901_191002.jpg 20190901_191012.jpg 20190901_194200.jpg 20190901_203001.jpg 20190901_213829.jpg 20190901_213854.jpg
    ct1932ford, rpm56, brEad and 5 others like this.
  11. x77matt
    x77matt
    One other exciting score that will be a nice addition to the roadster is the 25 louver hood I picked up from @koolbeans ardun coupe project. A friend bought the leftover rolling chassis and bits, and I ended up with the hood that will be really perfect with a SCoT blower peaking through the side louvers.....
    Just Gary, brEad, 51box and 2 others like this.
  12. x77matt
    x77matt
    Spent some time today with the grinder and a beautiful wood kit from Brad's wood. As with most things like this, it took the better part of the day to make the corners fit nicely....
    Still need to drill the holes and then do a final overall sand and shape of the sharp corners ....
    20190902_170336.jpg 20190902_150517.jpg 20190902_150529.jpg 20190902_150446.jpg 20190902_165309.jpg 20190902_165317.jpg 20190902_165326.jpg
  13. x77matt
    x77matt
    This weekend- finished up mounting wood and then moved on to the front floors. I decided to make them out of steel due to the extra room needed for the larger T5 trans and k member top brace. Still more work to do, but you can see where it's headed. I'll put some beads in them after it's all fabbed ...
    20190907_194911.jpg 20190907_194914.jpg 20190907_194919.jpg 20190907_201455.jpg 20190907_210852.jpg 20190908_181900.jpg 20190908_181855.jpg 20190908_184608.jpg 20190908_195648.jpg 20190908_200602.jpg 20190908_203707.jpg
  14. Nice job on the tunnel and firewall!
  15. Deuce Lover
    Deuce Lover
    And the column drop !
  16. loudbang
    Good work.
    brady1929 likes this.
  17. qzjrd5
    qzjrd5
    from Troy, MI
    Looks awesome dude!!!
  18. x77matt
    x77matt
    Thanks! I'm sort of inventing as I go, and so far I like how it's turning out. Good thing I am not getting paid by the hour, cause I do a lot staring and making scraps before it works well
    Also good thing there is a lot of talented metalworkers on the HAMB and Instagram who share their techniques.
  19. x77matt
    x77matt
    Thanks Mike!
  20. Drylake
    Drylake
    Looking great!
    loudbang and x77matt like this.
  21. brady1929
    brady1929
    Yes, it does look great.
  22. x77matt
    x77matt
    More weekend progress on the floor. Added beading detail, made a "glovebox" for the pass side and access hole for master cylinder. Still need to make some nice doors for the covers and add holes for fasteners.
    20190914_135533.jpg 20190915_110926.jpg 20190915_114231.jpg 20190915_114244.jpg 20190915_133551.jpg 20190915_135727.jpg
  23. Really nice work!
  24. Looks awesome. I have to do the same on my 36. Hope mine turns out as nice as yours.
  25. mikeyjoe
    mikeyjoe
    from DETROIT
    very nice craftsmanship Matt I dig it!
  26. x77matt
    x77matt
    Thanks Mike! Hope that panel is moving along!
  27. mikeyjoe
    mikeyjoe
    from DETROIT
    It's moving along
  28. the-rodster
    the-rodster
    Nice work!
  29. x77matt
    x77matt
    Worked on the doors for the access holes today. I used early Ford floor rivets to fasten the hinge. I think it turned out pretty slick...
    20190928_114804.jpg 20190928_132344.jpg 20190928_141227.jpg 20190928_144431.jpg
  30. x77matt
    x77matt
    Got my rebuilt rear shocks back from Mike at Mike's Speed shop in NC. They look great. I took some 32 front shock arms, shortened them 1.5" and they line up nice with the 36 bones. This will also make the effective stiffness from the shock greater.
