Hi, I have a 1932 pickup ford with original door levers and system. what is the best way to convert the driver door opening system to be lockable and can be open from outside. only the passenger door have a lock and can be open from outside. thanx
Ford didn't offer that option, the only way I can think of is to find another passenger side latch and modify it along with the drivers side latch to accommodate the locking mechanism part. HRP
You could do a locking handle. All though I did a quick search and didn’t see locking pickup handles, just car. Sent from my iPhone using The H.A.M.B. mobile app
Most of the big C stampings of the left latches had the spot where the lock cylinder would go. Even the holes in the stamping are there. But I think the cylinders and their cams and stuff are side specific, so you'd need to find a lefty cylinder to swap onto your latch. I recently found a perfect left 32 latch that has a 5-window length handle arm, and a lock cylinder on it. I'm going to use it on a 5-window, but I'm sure it was originally made for something else. Maybe it's a right side fordor rear?
I put car handles on my 34 truck because I like the look of them better and they both come with locks.
Correct I had a set of crapped out originals that I was going to rebuild for my pickup but in the end purchased a set of the new United Pacific ones. They were a good fit and option for me.
thanks for the reply, will check with United Pacific and look at 34 handle option, but I think I looked at this and didnt like the "curvy" look of them.
