1932 Ford Frame ASC rails with parts to put together a frame, will need a front cross member. Ford 9" is 28 spline and 4.11 gears, will need shortened to fit axles, but gets it to 59" wide flange to flange and will have 5 on 5.5" pattern. Magnum 4" dropped axle, Model A front cross member, 1937 Ford wishbone, 1935 Ford center section, Model T rear spring and metal tube rear cross member, new brake pedal, New motor mounts for 350 Chevy or stock mounts for flathead, 1932 Ford fiberglass grille sectioned and s.s. insert, some boxing plates, shock mounts. Lots of other stuff with it as pictured. **SOLD**
