Original 1932 Ford engine & transmission (missing shifter), with correct aluminum pan, big plug heads, and exhaust manifolds. I just removed this from a shed where it had sat since 1953. It was covered when I found it, but there has been water in the transmission (it wasn't covered). Transmission is missing shifter, but does have correct clutch lever & mount. Oil in oil pan looks good, but I do not know if motor spins. There is a crack in the oil pan, you can see it in one of the pics. Should be an easy fix. Correct 32 only big plug heads. Does have a 34 intake & distributor. 2000.00 OBO, may trade on other 32-34 parts. Can possibly deliver to Hershey if deposit made in advance. Thanks... Sam Barnes 423-571-5906
I have dropped the price to 1500...I feel that is a fair price since the block condition is ultimately unknown, but it does have the aluminum pan, original heads, waterpumps, & exhaust manifolds... Sam
