For sale: 1932 ford chassis Complete roller ready to go. Built by local speed shop Specs: Original rails built to factory specs Boxed with dimpled plates Posi front spring Chrome super bell front axle Round back spindles Disc brake conversion 5x4 1/2” lug Braided stainless brake hoses Through the frame brake fittings Chrome Tube shocks Rack and pinion Vega mount steering Pete and Jake’s Panhard bar Pete and Jake’s chrome hair pins Small block Chevy motor mounts Brookville k member Brookville hydraulic pedals Corvette master cylinder Wilwood proportioning valve All brake kind and residual valves ran Wilwood clutch master cylinder Wildwood clutch slave cylinder Pete and Jake’s rear ladder bar kit Chrome rear shocks Posi model A rear spring Fabricated model A rear crossmember Polished halibrand quick change 9” insert axles 9” loaded ford brakes Sitting on 5x4 1/2” roller wheels . This chassis is ready for a body ! Can provide more photos . Also have a set of modified 35 ford wires that can go with , will need lug adapters. I Can help ship. Chassis and parts are unpainted/coated. I can have everything done In black for extra fee. Serous inquires only . $10,000 You can’t build one for that Please call or DM 724-301-4736
