1932 Ford 5W Henry Steel Chopped and Channeled in the 70s
Discussion in 'eBay Ads & Links' started by 4wd1936, Oct 6, 2021.
  1. 4wd1936
    4wd1936
    from NY
    Here is one recently unearthed from the prehistoric 70s, a real Henry steel chopped and channeled deuce coupe. Actually rather well done in the time before rolling chassis and 1-800-hotrod on a real 32 frame. The body, even the paint is still rather nice in that it has been well stored for many years. If you are 6'+ things might be a bit tight but once you get in there it is not bad. It appears that the whole driveline may have come from a late 60s-early 70s Chevelle as the engine is a 010 350 with double hump heads, trans is 400 Turbo, rear a Chevelle 12 bolt. It appears that the builder may have also used the disc brakes on early GM spindles along with the master cylinder. The nasty sounding 350 seems to run well, transmission works as intended as does the 12 bolt. Even the steering powered by a reversed Corvair works well but because of the semi-retirement the last twenty years or so I would suggest a general lookover before extended driving. Interior and trunk is quite well done with all the gauges working along with a interesting under the dash interior light system. BTW the underside of the dash is completely covered/upholstered from one side to the other. Wheels are very, very nice Weld wheels from back in the day but the tires are aged. Exhaust is nice back to the mufflers, tailpipes should be added. There was an attempt at one point to join the billet crowd as attested to by the billet tail lights, electric trunk, mirrors, inside door handles, flip down license and glue in windshield all of which could be easily reversed. Inside has an CD player with fader on the ceiling(nicely done) along with an amp in the trunk, a bunch of speakers and some round tube behind the seat. Grille is nice steel, radiator is copper with electric fan and lights all seem to work. There is no E/Emergency brake or neutral safety switch so both of those items should be addressed. This 32 still has points and a hi-performance clear distributor cap along with a much newer Holley carb, fuel pump, starter and alternator. Title is a clear, clean VA item with a matching vin tag on the firewall. As always absolutely no test pilots and please, bottom feeding low ballers go elsewhere. Thanks
    catdad49 likes this.
  2. 4wd1936
    4wd1936
    from NY
    Now on Ebay! No reserve starting at $32.5k This is a real deuce coupe.
