1932 Ford 3 Window Coupe almost done Project .......All the hard work IS DONE !!!EVERY PART used for the build is BRAND NEW and TOP OF THE LINE PARTS !!! There is ALMOST FIFTY THOUSAND DOLLARS in receipts !!! The Flaming River column needs to be installed, the wiring harness and the STEEL front fenders.....ALL steel parts have been covered with etching primer for protection ...ALL fenders,running boards, Grille shell. hood top and sides are STEEL !!!! Car runs EXCELLENT and The BOB DRAKE 700R4 has Lokar shifter and all gears work and the WILLWOOD POLISHED 4 piston brake system is FINISHED ..... Here's some parts run down.... TCI chassis with HEIDT'S POLISHED STAINLESS STEEL front end with rack and pinion and polished calipers in front ...9 inch CURRIE Positraction rear with 3:89 gears, 31 spline axles with the large bearings. Engine is a BRAND NEW GM ZZ4 ( Dyno time ONLY !! ) built by pace performance with hot roller cam, and a BARRY GRANT 3 Two barrel induction system ..... ALUMINUM Driveshaft with Hi PO Universal joints.. Body is a TOTAL PERFORMANCE 'glass 3 window built by ROD ACTION and is EXTREMELY STRAIGHT !! Purchased off the SHOWROOM FLOOR .... ALL STEEL PARTS are from BROOKVILLE ROADSTER ... Exhaust is done and is ALL 2 1/2" MANDREL BENT STAINLESS STEEL... power windows are installed, tinted glass, COKER Radial wide whitewalls on HOT ROD wheels with caps and trim rings ... now .... THIS IS JUST SOME OF THE PARTS !!!!!!! ALL PARTS NEEDED TO FINISH are INCLUDED .... gauges, banjo wheel , etc, etc, etc, etc .......... If you know how much $$$$ goes into building a SWEET HOT ROD like this ....and what was ALREADY SPENT --- BESIDES JUST THE PARTS .... you KNOW she is a STEAL !!!!!!!!!!!!!!!!! She will be one FAST, GREAT HANDLING and LOOKING Hot Rod that we ALL WOULD DIE FOR --- and --- ON THE CHEAP !!!!! PM or call me at 856 764 9300
