Does anyone know if they make a 1932 aftermarket, 1" drop front cross member, with ford Flat head V8 motor mounts?
I don't think so. I looked and looked for one like that and didn't find one. Ended up buying an original crossmember. Will make the drop at the axle instead. Or perhaps cut out the part where the spring goes, raise it an inch and re-weld it again.
I thought that most guys use a model A front cross member. And use your creativity to put in your motor mounts.
Closest thing I know of is the Socal piece: P/n 001-69611 Sent from my SM-G965U using The H.A.M.B. mobile app
