1931 Ford Pickup project https://www.jalopyjournal.com/forum/media/albums/ford-project.46844/ 1931 Ford pickup cab Ford Model A frame 1949 Ford 8BA flathead engine (disassembled for machining) Flathead motor mounts Evans 3 carb intake 1939 Ford banjo rear end w/ torque tube, radius rods and stock spring Ford Model A rear spring Posies Super Slide de-arched reverse eye front spring Magnum 5” dropped and drilled front axle Pete and Jakes front spring perches F1 style shock mounts 1940 Ford split wishbone w/ weld in bung kit So Cal stainless spring shackles F & R New kingpin set U-bolt kits F & R Ford round back spindles New wheel bearings Various backing plates Ford steering box 4) drum brake full rebuild kits 4) 16”x 4” Ford steel wheels 4) 16” Ford wire wheels 2) 16”x 5.5” Coker whitewall tires 1946 Ford steering wheel Likely other bits forgotten about. Collected as parts so no title. e-mail for pics, questions - [email protected] IMG_5387 by onespeed posted May 28, 2018 at 4:18 PM [email protected]
