1931 Ford, Model A, Coupe, Hot Rod,Street Rod, 5 Window, 1932
Discussion in 'Cars For Sale' started by Steadfast mfg, Dec 29, 2018.
  1. Steadfast mfg
    Steadfast mfg
    City: Mansfield
    State: Ohio
    Price: 45,000.00
    Everyone knows that the Model A Coupe on deuce rails is the coolest Hot Rod to build right now.
    Here is your chance to own a Hot Rod that will demand attention when you roll into any Rod Run or Goodguys show!
    I personally don't want to waste my time building a Hot Rod that wont get attention and neither should you! I want something to sit right, looks right and demands everyone's attention! 43878394_256353318403382_5930829891330113536_n.jpg
    Since not everyone can get that perfect stance and use the right combo of parts, I am making it easy by setting it up for you!
    YOU can make this Steadfast Hot Rod all YOURS by setting it up with YOUR COLOR of choice and YOUR INTERIOR color & style!
    One thing you will notice is how low it sits. This Hot Rod is 100% drive-able at this ride height.
    Johnsons Hot Rod Shop rear sway bar that helps eliminate body roll. This way you don't have to worry about the tires rubbing the body around an 80 mph entrance/exit ramp!
    (Will consider removing the engine and transmission from this package to make it less expensive, if you don't want the Caddy)
    If you have any questions regarding this Hot Rod feel free to contact Henry at Steadfast Mfg and ask away!
    43669672_1498329220267299_3620429359174647808_n.jpg 43878394_256353318403382_5930829891330113536_n.jpg 43669672_1498329220267299_3620429359174647808_n.jpg 43952531_852610808196232_2770898425892306944_n.jpg 43951645_188842542010259_4898451200845807616_n.jpg
    Here's a list of what you get....
    Steadfast
    Perimeter ~ Chassis for a High boy/flat front/Model A pinched rear 3,200.00
    • 5in. Dropped I Beam 400.00
    • Durant Super Low Front Spring 220.00
    • Spindles 225.00
    • Front Shocks 75.00
    • U-bolt Eliminator 50.00
    • Adjustable Perches 140.00
    • So Cal SS Front Shackles 90.00
    • King Pin Set 50.00
    • Tie Rod Kit 77.00
    • Drag Link Kit 81.00
    • Vega Box 350.00
    • So Cal Pitman Arms 70.00
    • Steering Arms 95.00
    • Vega Box Mount 50.00
    • Lower Shock Mounts 70.00
    • Spin Nuts 15.00
    • Front Brakes Johnson Kinmonts 2,800.00
    • Quick Change Rear 3,250.00
    • " shipping 150.00
    • P & J Ladder Bars 450.00
    • Set up for Johnsons Rear Sway Bar 250.00
    • Rear Pan Hard 132.00
    • Lower Shock Mounts & Brackets 185.00
    • Rear Spring 400.00
    • Rear Spring Hangers 100.00
    • Rear Shackles 90.00
    • Rear Shocks 75.00
    Wheels & Tires
    • Fronts: 16 x 4.5 / 500.16 Dirt Trackers
    • Rears: 18 x 7 / 700.18 Tires
    • Wheels Painted Black, Tires & Tubes $2,800.00
    Miscellaneous
    • Walker Radiator for Cadillac Motor
    • Brookville '32 Radiator Shell
    • Steadfast Custom Seat Frame ~ New
    • '32 Car Dash
    • So~Cal Gauge Insert
    • and miscellaneous extras
    Body
    • '31 Steel Five Window Coupe
    • Steadfast Floors
    • '32 Style Firewall installed
    • 4 1/4 inch Chop
    • Brookville Deck-lid
    • Brookville Cowl Vent installed
    • New Wood Kit
    Engine & Transmission
    • 1956 Cadillac 365ci. Factory 2x4 intake with number matching carter WCFB carbs. It has been rebuilt and has a isky cam.
    • Tremec TKO 600 $2,895. ( have everthing Wilcap to adapt motor to trans)
    Note: Parts are Pete & Jakes unless noted otherwise.
    This is a "Roller Project" unfinished, not currently running Hot Rod ... contact Henry !
    Located in the middle of Ohio, USA!
    Delivery available, message us with your zip code for delivery fee quote.
    Item being offered locally auction can end at any time!
    Steadfast Manufacturing specializes in custom hot rod fabrication and product design. We manufacture and sell our own products that are designed and built in our own facility. None of our products are manufactured outside the USA.
    Additionally, we are authorized sellers of high-quality hot rod and performance parts from Pete and Jake*s, Perfection Hot Rod Parts by Johnson's Hot Rod Shop, Brookville Roadster, John*s Industries 9 Inch Factory, Vintage Air and LimeWorks, just to name a few.
    Follow us on Facebook or Instagram: at steadfastmfg
    Rick28 likes this.
