1931 Ford A Coupe +++ (((Project))) (((Clean Clear Open Title As 1931 Ford Coupe))) Nicest Solid Body I Have Ever Seen With No Patch Panels Or Signs Of Body Work. (((98% Rust Free)))... A Couple Of Very Small Bubbles, Lower Cowl, Can Be Treated. Perfect Sub Floor, No Rips No Tears. Full Original Floor Down To The Wood Factory Rumble Seat & Panels. Front & Rear Seat Risers & Panels & Sliders, Excellent Gas Tank, Dash, Rail - Clean... Chopped 4 1/2"s Correctly with Relief Cuts & Body Worked... Super Clean All Steel Sheet Metal, Rear Fenders, Hood, Aprons, Floor...Excellent Wheel Wells (((Original)))... Doors Open & Close & Latch Correctly... Most Of Original Wood Is In Good Shape... Original Top Wood Is Original & Good Cond... Original & Aftermarket Deluxe Tail Lights... All New Handles & Misc. Super Clean Original 4 Pc. Hood, Clean Grill Shell, Pretty Much Complete Body Minus The Front Fenders & Headlights... Clean Original Un-Boxed Frame, Front 1/2 Cleaned & Painted, New 4" Dropped & Drilled I Beam Axle, 35-48 Spindles, New Reversed Eye Spring, Machined Model A Split Wish bones & New Ends... New Tie Rod Ends, New Lower Shock Mounts Ect. 1935-1948 Ford Hydraulic Brakes, ((( Need Rebuilt))). No Rear End Or Mounts... Blank Canvas, Street Rod - Traditional (((Save Thousands))) On Body Work & Rust Repair... (((Might Separate Frame & Suspension Sheet Metal Before I Put It On eBay))) Asking $9,500 OBO Ken 702 575 7100
