Projects 1931 Dodge 3W coupe build
Discussion in 'The Hokey Ass Message Board' started by bostonhemi, Dec 4, 2012.
  1. bostonhemi
    bostonhemi
    Installed the starter, driveshaft, connected flex plate to converter and alternator
  2. bostonhemi
    bostonhemi
    331 hemi running in chassis
  3. bostonhemi
    bostonhemi
    I’ve made progress. Maybe this summer it will be drivable. Eventually all the fenders will go back on. I have a lot of small things to do so I’m going to try to get some help to move it along. The biggest thing to be done is the body. I can finally see the light at the end of the tunnel.
  4. bostonhemi
    bostonhemi
    I had the fenders stripped treated for rust and primed until they get welded up.
    kidcampbell71, TFoch and nunattax like this.
  5. Great to see some progress!
    bostonhemi likes this.
  6. bostonhemi
    bostonhemi
    The s10 rear end is out and replaced with a 60’s nova posi. The front springs were cut now the stance is where I want it. So far I’m very happy with Joe’s work.
    TFoch and hfh like this.
  7. bostonhemi
    bostonhemi
    A little progress joe started making new rocker panels, almost finished steering and will start wiring n gauges soon.
  8. I like the stance!
  9. bostonhemi
    bostonhemi
    The wheels and tire size was fixed along with the other rocker panel. All the wheel spacers are gone.
  10. Brand Apart
    Brand Apart
    from Roswell GA
    Just found this thread. Nice job. Don't worry about the Dyno HP. Torque is over 300 ft lbs and a nice curve that will really move a light car like this. Of course the appropriate gear ratio is a big factor as well. Plenty of time to play with and fine tune it once it's drive able and looking good, almost there!
  11. bostonhemi
    bostonhemi
    Thanks, the s10 4:10 rear is gone it’s a Chevy rear from 60s now with either a 323 or 308 rear but the goal this year is to get it drivable. I’ve got the Dyno results somewhere. The mechanic told me the same thing about the tork.
  12. bostonhemi
    bostonhemi
    I found a dyno chart.
    Big mike 1968 likes this.
  13. bostonhemi
    bostonhemi
    I know it probably won’t get painted until next year but I’ve finally decided on the paint job.
    kidcampbell71 likes this.
  14. bostonhemi
    bostonhemi
    I was really excited today. There was finally some progress and it looks hopeful I might be able to drive the 31 this summer thanks to Joe.
    TFoch and slayer like this.
  15. Glad to hear this!
  16. bostonhemi
    bostonhemi
    Finally a little more progress
    Budget36 and TFoch like this.
  17. bostonhemi
    bostonhemi
    TFoch likes this.
  18. @bostonhemi Sounds sweet! That Hemi really fills the engine compartment!
  19. bostonhemi
    bostonhemi
    Taillights are together
  20. Nice! Are you allowed to run the year of manufacture plates in Mass?
  21. bostonhemi
    bostonhemi
    I don’t think so
  22. We can use them up here in NH if you have antique plates. You put the year of manufacture plates on the car and keep the plates given to you by the DMV somewhere in the car.
  23. notaford1
    notaford1
    from webster ny
    535AF865-1B5D-49CB-9C81-1B6E47821DDA.jpeg Good choice !!!
  24. bostonhemi
    bostonhemi
    Exhaust system done, custom made panels almost done and top section of hood being mounted soon. Materials for bench seat in soon to be used for upholstery .
    55Deso and TFoch like this.
  25. bostonhemi
    bostonhemi
    I’m getting started on the bench seat.
    TFoch likes this.
  26. bostonhemi
    bostonhemi
    I had the wrong person sew the bench seat cover for me not being able to do that part myself without the right tools. Fortunately
    I finally found someone local who fixed it for me.
    slayer and TFoch like this.
  27. Looks a lot better!
  28. bostonhemi
    bostonhemi
    I had some one do the wiring and some other work. It’s almost ready for a drive hopefully this spring. The Ebrake is in and the wiring is close to being finished.
    I need a new windshield frame and glass. Does anyone have a guy or advice? A friend recommended a guy in North Carolina. A8907730-0B94-4B57-8256-7323554ADD1B.jpeg
    2Blue2 likes this.
